2 members (PAUL Berardi, 78buckshot), 175 guests, and 3 robots.
Topics128,081
Posts1,056,078
Members48,434
#1502294 05/26/2023 9:04 PM
Thinking of changing to 12v
Only things I can think of to be changed
Coil
Blower motor
Fuel gauge????
What did I miss
Jack Ryan #1502295 05/26/2023 9:29 PM
Generator to alternator. Battery. Bulbs.
1949 gmc 1-ton
Jack Ryan #1502297 05/26/2023 9:30 PM
Although you can use a 12v DC generator and don't have to switch to an AC generator (alternator).
1950 Chevrolet 3100 (Ol' Roy)
Jack Ryan #1502305 05/26/2023 10:46 PM
Adding a ballast resistor, a stomp starter switch with a bypass lug on the side and a wire from that lug to the coil + terminal will make for longer lasting distributer points.
Jack Ryan #1502331 05/27/2023 12:42 AM
Check the Stovebolt Tech Tips for a tutorial on changing from 6 volts to 12 volts.
Jack Ryan #1502593 05/28/2023 5:19 PM
Thanks guys
Jack Ryan #1503045 06/01/2023 12:26 AM
Did the same conversion to my '50 many years ago. Very glad I did it. Wait til you pump your 6v horns with 12 volts. Yahoo!
Craig
Jack Ryan #1503104 06/01/2023 1:25 PM
That’ll sound cool
Someone at classic parts told me a DA plug wasn’t needed if I didn’t have an HEI ignition
Does that sound right?
Thanks again
