5 members (Gdads51, Rich'sToys, jasrking, TooMany2count, FishinToms53), 117 guests, and 1 robot.
Topics128,126
Posts1,056,354
Members48,441
Page 1 of 2 1 2
#1502784 05/30/2023 2:29 AM
My speedo used to bounced really bad. Lately, it stops bouncing above 30ish mph and just pegs and 90.
I bought a new cable and hooked up just the dash end tonight. Ran the other end with a drill. Still some bounce, much better, but the speedo head makes a decent amount noise.
I figure it’s time for a clean and lube at minimum. Anyone have a procedure for me?
1951 3100
JW,
Check out this previous thread on your topic. This reply in particular may help the most.
Originally Posted by 56chev
Your problem sounds just like the problem I had in my 56 210. The needle would start bouncing around and making an awful screeching noise. Here is how I lubed the speedo in my car: (your truck is probably similar)
Remove the speedo assembly from the truck.
Where the cable screws onto the speedo, look for a little brass cup in a hole. Dig out the cup with a pick or small screwdriver.
Inside the hole will be a little piece of felt. Take it out and clean it with a solvent and dry it completely.
Put a few drops of machine oil on the felt piece, and a couple of drops directly into the hole in the speedo. (most folks recommend sewing machine oil for this, I used Hoppe's gun oil. The colorless oil. Not the Number 9 solvent.)
Replace the felt piece in the hole and the little brass cup.
Use a small drop of oil to lube any other moving parts. Wipe off any excess.
Then you can put it all back together and the noise will be gone.
56chev
Lots of great helpful tips in there for the majority of the maladies that affect our AD speedo's.
Just my $.02 worth, but sounds like you have a speedometer "head" that needs some cleaning/lube. There are also several notes about over-tightening the speedo cable connector at the speedometer end that can cause similar grief.
Let us know how this turns out please.
Dan
~ Dan
1951 Chevy 3 window 3100
That is a helpful thread and yes, I agree, some Speedo head removal/lubing sounds like the ticket.
How does a guy go about removing the head?
1951 3100
JW,
You will need to pull the entire speedo assembly from your dash to get in there and do the head lubrication.
See Page 12-33 of the '48-'51 Shop Manual for how to remove the speedometer and head assembly from the housing.
For further "lube" work on the speedo head, check out this video. It isn't for an actual truck speedometer, but the early Chevy speedometer being worked on is similar enough to your needed disassembly and lubrication process. Sorry about the length of the video and the inevitable ads. The meat of the lube process starts after about the 21 minute mark.
I would say have fun getting to this, but getting the speedo cluster out is not a "fun task" in my book.
Don't forget, for safety sake, disconnect your battery before getting under there. Don't want to let any "smoke" out under the dash. big_eek
Good luck and hope your knuckles retain most of their skin! wink
~ Dan
After much frustration, I got the speedo head out. As I was cleaning the lubrication hole, I broke the needle.
Is this replaceable? If so, how?
1951 3100
Ok, I ordered the needle from Jim Carter, but will definitely need some help with the install. Looks like a very delicate procedure.
1951 3100
JW,
Just a suggestion, but try to use the Search The Site tool link.
I did a quick check with the question "How to replace my speedometer needle" and it provide a whole list of links to previous conversations that discuss pretty much anything you need to know on the topic.
Lots of previous knowledge available in there to help you with your question. wink
Dan
~ Dan
That does help. My previous searches didn’t turn up any useful results.
Something that’s not totally clear to me even after reading those threads. The Jim Carter website mentions little tabs that are bent around the back of a cast hub.
The threads I found mostly described securing the shaft/spindle, and just prying the old needle off. In so doing, are we removing said hub along with the chrome outer covering that has the needle?
1951 3100
JW,
I haven't actually attempted that, although I do need to eventually as my needle has been broken for some time.
I think sometime in the past year or so, member "JonG" did a long post with extra details on the repairs. I didn't find it in my search, so it may have been more than a year back.
Perhaps he will come back and re-share his wisdom?
Dan
~ Dan
I did find an old thread where he detailed replacing the “spindle/shaft.” I didn’t immediately see much about the needle part but may need to look closer.
1951 3100
This thread actually does mention the needle hub removal.
https://www.stovebolt.com/ubbthreads/ubbthreads.php/topics/1407120/2.html
1951 3100
2 Offline
The needle is friction fit
There are special tools to pull it straight up
I usually use two screwdrivers to pry it straight up
Protect surfaces with tapes
If the shaft snaps off then you will need to fix that too
I usually crimp the new needle onto its counter mass and press them on together as it’s very difficult to bend the tabs on the needle metal cup after the counter mass is pressed onto the needle shaft.
I use my fingers to press new needles into place
No hammering
-s
Good stuff, thanks!
By the way, I have done a lot of “not fun” things on my truck. Removing the speedometer head would be near the top of the “not fun” rankings.
I’m going to try to button up as many things behind the dash as I possibly can….while I have some access.
I don’t ever, ever want to do that again.
1951 3100
One of the old threads I was reading, mentioned re-magnetizing the speedometer. Is that something that should be done as of preventative medicine while I have things apart? Or only if I have a known issue?
FWIW, once I cleaned and lubed the mechanism, what’s left of the needle stays steady and the works run nearly silent.
1951 3100
New needle arrived. After 20 or so very tense minutes, it’s installed.
Should I do a preventative remagnetizing? When I run it with the drill, it seems pretty stable.
1951 3100
2 Offline
Turn the speedo input at 1000rpm should indicate 60mph
Remagnetize only if it’s reading low otherwise it’s not going to do anything.
Alternatively, if you set a power drill on its low setting
And use an rpm gauge to check the drill speed
You can then linearly interpolate or extrapolate the expected mph indication knowing that 1000 rpm is 60mph
Example
Drill is spinning at 800 rpm
800/1000x60 = 48 mph
-s
Example
-s
I spun the drill at both low and medium speeds, but have no way of knowing how many RPM that is.
1951 3100
You can get a cheap optical tachometer to figure that out. Search Amazon for "optical tachometer handheld".
Moderator, Electrical Bay
Find a common lp turntable...it will have a turntable with a diameter of around 12 inches...maybe 11. Something like that. It ought to have a rubber edge on it. Most of them did. Hold the "wheel" made by the outside edge of your speedometer as shown below...the spinning part (which should be a diameter of around 3/8") against the turntable (set for 78 rpm speed). Assuming there's not too much internal drag, your speedometer shaft will be spinning at 1000 rpm or very close to it. Good enough to let you know if you're wildly off or reasonably close. I can offer plenty more advanced math but that's as far as I can go quickly this afternoon. Good luck.
~ Jon
I downloaded a strobe tachometer app on my iPhone and put a white mark on the drill. The app says medium speed on my drill is 1164 rpm. The speedometer reads roughly 48 mph at that speed. I have no idea how accurate the app is.
I’m gonna borrow my parents turntable after bit and try Jon’s test. But test #1 shows the Speedo is off.
1951 3100
2 Offline
It doesn’t hurt to re magnetize it ever
Just put the magnets on as original north south and let it sit overnight
Do I have to take the needle back off to get that far in? I’ve seen the diagram of the poles in the thread I linked earlier. What do you mean by original north and south?
1951 3100
I don't remember about that but offhand I'd say you only need to remove the unit from the case. If you want to know what is north and south, just hold a compass near it. If the needle runs toward the area...you're looking at the south pole there. If it runs away...you're looking at the north pole in that area. Opposites attract. Same with the magnets you have. You can use the compass to mark those as to N or S.
~ Jon
2 Offline
Whatever way the magnets want to naturally stick to the poles in the speedo is correct
The field is going to re-enforce the magnetism the correct way
The goal is to make one side of the spinny part north and the other side south
There was a thread where I drew a diagram to explain it
Don’t know how to link to it at the moment but assuming you found it
Do it like that
Also folks said they had good experience magnetizing like in the old science books way
Where you stroke the magnet onto the part and drag it off repeatedly in the correct orientation with aligned poles
I tired that a bit and then left the magnets affixed to the speedo part overnight and whatever I did worked perfect because my Speedo was dead on accurate the next day when I did a trial run.
-s
2ManyTrucks,
Is this the previous post you were referring to???
Since the picture displays are having an issue this morning (can't see right now what your pics included), figured I could at least link your older post back here so when that problem is resolved we can see what you described.
Looking forward to seeing those pics and hoping they are helpful to all reading here.
Dan
~ Dan
This is the thread I was using for the magnet procedure. https://www.stovebolt.com/ubbthreads/ubbthreads.php/topics/1407120/2.html
I have disassembled to this extent:
Before I screw something up, wanted to ask what need to be removed in what order to access the magnets. I did buy some rare earth magnets today.
Please advise.
1951 3100
2 Offline
The needle pulls straight off
Then two tiny screws to remove the face plate
After that I think it’s maybe only clips and pins but it will be fairly obvious
The needle cup and it’s clock spring come out together and just be gentile with them and it should be easy to reassemble after
You have to remove a few worm gear drives
And get the magnet exposed
It’s very doable and it should all go back together as it came apart
Do not get any oil or lubricant onto the clock spring or else it will collect dirt and could cause binding of the spring from winding to winding resulting in poor operation.
Just try to pay close attention how stuff comes apart to remember how to put it back together
There are many junk trucks with usable parts if anything breaks don’t freak out, it can all be found still fairly easily and cheap
-s
Do it like that
-s
My magnets seemed plenty happy to bridge the two poles either way. Attached picture shows how I have it set up now. The nuts in the middle are shims to span the gap. Let me know if that looks wrong.
The other pic is to illustrate a question I have. Does the hook end attach to the little protrusion I’m pointing at with the toothpick, on the left? Or does it attach to the other apparatus on the right. And if it attaches on the right, to which part of that apparatus?
1951 3100
Found an old DADS50 post that may have answered my question. See pic
1951 3100
2 Offline
I’m a bit concerned your magnets maybe too small to generate enough flux to fully saturate the speedo poles.
But maybe it will work
If your Speedo still reads low when you are done I would suggest larger magnets
You can’t go too big, the poles have to reach their saturation point.
That and adding the nuts and metal to complete the flux path adds reluctance to the circuit which also reduces available flux.
Larger magnets bridged pole to pole is what worked for me.
-s
You might be right, but those little magnets are crazy strong. Al kinds of warnings and they come in a child proof bottle.
I wish I would have bought two sets of them to avoid the nut “shims.”
I’ll see what happens and report back. Aside from the magnet strength, are the magnets positioned in a similar way to what you did? I used your drawing to guide the process.
Disassembling down to this point gave me the opportunity to clean and lube several more gears.
1951 3100
2 Offline
Yeah the magnets look correct position for the poles
Keep us updated
-s
For a quick function test before I reassemble and run the cable in a drill again….
I think I will shorten the stack by removing the nuts, and hold the stack in between the two poles, with the stack polarity reversed. It should spin, or at least start to turn.
Am I thinking of this correctly?
1951 3100
2 Offline
I wouldn’t reverse the magnet polarity and introduce them to the poles
That will immediately start to desaturate the poles in the speedo
Just reassemble and do your test
If it’s good - great
If not - at least it’s not back in the dash
-s
The strongest magnets you might find are those removed from old PATA hard disk computer drives. Possibly dead SATA drives, however by the time the SATA scheme took hold it was discovered weaker magnets would suffice.
If this speedometer project goes toes up on you (which I don't think it will) and if you are going to be swapping rear end and transmission anyhow, I am considering making a "look-alike" GPS speedometer (my plan is to make one which will simply bolt in to the stock housing and use a new-style face plate either with or without turn signal indicators). You can see what mine looks like below. It isn't exact, but it is as close as anything I've seen. It uses the old style bulbs (plus an led for high beam) so it will not look different at night. One slight drawback is making the face plate. I will have to enlist some help in writing the CNC program since it will need to use X-Y-Z and not just X-Y (which I can handle).
~ Jon
2 Offline
The engineer in me really appreciates your solutions Jon
I don’t mean any disrespect I love reading your posts and I do occasionally go down the same path
I worked in tech in Silicon Valley for 17yrs
We had many magnets in all sorts of designs
It’s a very complicated field (pun intended)
Old disk drive magnets are the same bulk strength as the ones I suggested, about an n41 rating, but drive magnets are very specific shapes that are more difficult to work with
And as long as the magnets can make the speedo pole reach saturation that’s all that matters
Gps is already on a planned obsolescence schedule
Sure other countries are picking it up
Pretty much All gps modules support Galileo and glonass now but I like not relying on a satellite
Besides, only a good old speedo tells you how fast the tire is spinning when your stuck
And it will never go obsolete
I’ve had too many overly complicated solutions fail in my life where the tech changed enough that it was almost a redesign to maintain it
I learned that lesson now, keep it simple and serviceable.
-s
Update:
Reassembled and ran the drill again. Good news is the needle is much steadier. Bad news is that the speed per drill rpm is way worse now. Like, twice as bad.
Wondering what I did wrong. Need stronger magnets? I don’t understand how it could have gotten worse.
1951 3100
2 Offline
Clock spring maybe too tight? Or has oil or lubricant on it?
Does the needle have friction on it? When you move it by hand and release it, it should have the elegance of a butterfly and move swiftly but gracefully to home and even bounce a bit with speed as it drops to the 0 peg.
The good news is the magnet poles can always be fixed
Maybe time for larger magnets and a video of what it’s doing
-s
I can get a video of what it’s doing currently. Don’t have access to any stronger magnets tonight.
1951 3100
1951 3100
Page 1 of 2 1 2
Moderated by  ndkid275, Phak1
