1 members (klhansen), 173 guests, and 3 robots.
Topics128,080
Posts1,056,317
Members48,442
I have this carb on my 270. It has set for a while and the adjustable jet was seized. I removed it to clean it up.
What packing seals the adjustable stem when you tighten the nut? I had some gray, lead like material crumble out on disassembly.
Also looking for a source for replacement if necessary.
Thanks for any and all responses.
Jeff
"Do not walk behind me, for I may not lead. Do not walk ahead of me, for I may not follow. Do not walk beside me either. Just leave me alone, you're starting to freak me out."
1957 GMC 150
Contact Jon (Carb King) at The Carburetor Shop. He's a member here, but I don't think he accepts private messages. His phone number is on his website. Jon has (or can make) parts for everything since Fred Flintstone put triple carbs on his dino-mobile!
Carburetion specialist
A number of different materials were used, but felt was the most common used by Zenith.
If you do not have access to felt, try an older hardware store for the graphite impregnated string faucet packing.
OR
If you need to do a carburetor rebuild, the felt is contained in the kit we make.
Jon
The Carburetor Shop
Thanks for the replies. Are there new adjustable jets available for this carb? Thank you
1957 GMC 150
You would have to have the identification number of the carburetor, and then check a bill-of-material. It isn't a one-size-fits-all-works-on-none; there are variations.
Jon.
The Carburetor Shop
I'm fairly sure the 1955.2-60 GMC Master Parts Book only lists one adjustable jet assembly for the 1 barrel Zenith carb. Heading out to a graduation party in a few minutes, but I'll look it up when I get home.
Jeff: Where in Hays County? I'm about 10 miles mostly west of Fredericksburg.
My brother's over in San Antonio. If I ever come out there to visit I'll have to look you guys up.
1950 Chevrolet 3100 (Ol' Roy)
Please do.
I was wrong in stating that the 55.2-60 GMC Master Parts Book only lists one part number for the Zenith adjustable main jet. That book does not list the adjustable jet at all.
The 1939-53 GMC Master Parts Book DOES lists just one part number for the Zenith adjustable main jet. 2233002. According to that book (see first picture below) it was optionally used on 100 through 350 series GMC trucks in 1939-50.
The second picture shows this part number (2233002) in a "GMC Engineered Accessories" catalog from 1950. There is a very interesting (to me anyway) statement in this document that says "and can furnish normal mixture when the convenient adjustment is turned all the way out". To my feeble brain that means that the original high speed jet is still in place while the adjustable jet is installed. How else would the "normal" mixture occur when the adjustable jet was full rich?
To support my opinion I've included the third and fourth pictures which are taken from a Zenith service manual dated 2-1-61. Item 53 is either a cap or the adjustable jet. Note that there are two parts listed for the adjustable jet, one "used with main jet" and one "when no main jet is used.
I'd like to get CarbKing's opinion on my comment about leaving the original jet in place when the adjustable jet is installed, even if it is that I am full of $#it.
Bill - you pretty well summed it up; some of the "adjustable main jets" are complete (different orifices), others are an "adjuster" to lean the mixture of the main jet (still in place). As I posted, not a one-size-fits-all-works-well-on-nothing.
Additional research with the part number of the carb would be involved; plus one needs to look at the carb in question to see if the original main jet is still in place.
Sometimes, folks will replace the main jet with a LARGER main jet, then add the adjuster.
Jon.
The Carburetor Shop
