0 members (), 72 guests, and 1 robot.
Topics128,196
Posts1,057,394
Members48,471
In reviewing the pantina prep forums and web sites.
I saw several on using steel wool and scotch-brite pads etc. Mostly of the finest grades. Some using S.O.S Pads.
That got me questioning a lot of things since I know the use of steel wool for wood work as well as some metal prep.
So here are some fine and ultra fine smile details on what is what.
First of S.O.S Pads are a BLEND not a single grade steel wool.
Direct from manufacture because I asked.
Quote
Thank you for contacting us at S.O.S.
I am happy to assist you. S.O.S steel wool soap pads are manufactured with a blend using grades 0 and 1. There are 8 grades of steel wool: 0000 = finest, 000 = extra fine, 00 = fine, 0 = medium fine, 1 = medium, 2 = medium coarse, 3 = coarse, 4 = extra coarse.
If I can be of further assistance, please let me know.
Sincerely,
Kimberly
S.O.S. Consumer Care
Now there is no direct equivalent for steel wool grade to sand paper grit.
And using it wet or lubricated vs dry also makes a difference.
But just for swag here is what the wood working guys use as a estimator.
4/0 steel wool = 400 grit sandpaper
3/0 steel wool = 280 grit
2/0 steel wool = 180 grit
2/0 steel wool = 120 grit
1 steel wool = 100 grit
2 steel wool = 60 grit
3 steel wool = 50 grit
4 steel wool = 36 grit
Anticipating the next question:
White Scotchbrite = 1200 grit (it has no abrasive)
Gray Scotchbrite = about 400 - 600
Maroon Scotchbrite = about 220-280
Green Scotchbrite = about 150 - 180
Be a little careful. Different manufacturers of non-woven abrasive material may be somewhat different. The above is for 3M Scotch-Brite brand.
And S.O.S Pads do not use the period after the last S. Because S.O.S. is not trademarkable according to the Govt. So they just pulled of a period.
Last edited by Peggy M; 05/25/2023 3:08 PM. Reason: changed to set off quoted message
Where does the beige (brown?) Scotchbrite fit in?
Try this....
Mike
1940 Chevy 1/2 Ton presently... Almost done
1940 Chevy Business Coupe... In pieces
Thanks!
