7 members (Wayne67vert, baldeagle, 74cheyennesuper, NorCal52Suburban, Ponchogl, Peggy M, NJC), 60 guests, and 4 robots.
Topics128,014
Posts1,055,328
Members48,419
#1501904 05/23/2023 10:48 PM
Crusing in the Passing Lane
Has anyone found a tool for forming new ends on vent cables? I need to shorten both on my ‘55. I am sure factory had one.
Ed
EdPruss #1501914 05/24/2023 12:41 AM
I am going to guess that the main cable is very stiff (hardened or spring steel) and will require annealing in order to make that bend.
That requires heat until light red then allow it to cool naturally. Then you can readily bend it to that shape.
My concern would be that this annealing process may soften the adjacent straight section of cable, rendering it subject to bending under stress of pushing the lever.
You may be able to restore the stiffness of the cable by heating to red hot and quenching it in oil.
EdPruss #1502021 05/24/2023 11:35 PM
Got it made. Started circle with needle nose pliers, when full circle finished , ground off first leg, grabbed from outside and completed full circles, practiced on cut off pieces.
Ed
EdPruss #1502022 05/25/2023 12:13 AM
Good deal! You may have saved yourself a perfectly good cable from total destruction by not attempting my half-baked idea. smile
EdPruss #1502054 05/25/2023 10:49 AM
52Carl,
Heating it like you suggested was on my list to try, since I had extra cable to try.
Ed
Ed Pruss At home 60 years ago we had a set of German made (with round tapered jaws ) that would make those right up.I still use that same pair today. Don't anneal but maybe I should,have to experiment a little on that.
fixite7,
Do you have a picture of that tool?
Thanks, Ed
EdPruss #1502646 05/28/2023 10:57 PM
EdPruss Those pliers are like a short pair of needle nose (no cutter) with round tapered jaws. Up next to the hinge jaws are square perfect for a 90 degree bend,Krauter brand on the pivot point. Great for electrical eyelets on copper,music wire,or just any wire.
