4 members (59 fleet, mason86, Samantha, dt235sd), 29 guests, and 3 robots.
Topics128,030
Posts1,055,424
Members48,422
#1501945 05/24/2023 12:41 PM
Crusty Old Sarge
Crusty Old Sarge
I have gutted the cab of my '59 getting ready for patch panels, doing so I found the kick panel vent was severely rotted out. The issue I'm having is locating a replacement panel for the vent assembly. Does anyone know a good source for the vent assembly on a Task Force truck?
Drivers Side Vent
~ Craig
1958 Viking 4400
"The Book of Thor"
Read the story in the DITY
1960 Chevrolet C10
"A Family Heirloom"
TUTS 59 #1501967 05/24/2023 4:22 PM
I just bought a pair for my 57. They fit well. From Classic Chevy Truck Parts. Others sell them too.
Larry
TUTS 59 #1501971 05/24/2023 5:14 PM
Crusty Old Sarge
Crusty Old Sarge
Larry, thank you. I have looked at many vendors and all show the outer panel and the inner kick panel repair piece but not with the vent assembly. I looked at CCP and that is the correct piece, at $149.00 I guess I'll need to bite the bullet and order them.
~ Craig
1958 Viking 4400
"The Book of Thor"
1960 Chevrolet C10
"A Family Heirloom"
TUTS 59 #1502015 05/24/2023 11:00 PM
O Online: Content
With a 64 year old vehicle, you're happy that parts are available at any price.
1950 Chevrolet 3100 (Ol' Roy)
TUTS 59 #1502027 05/25/2023 1:10 AM
Crusty Old Sarge
Crusty Old Sarge
I was kicking around the idea of eliminating the vents as I plan to add A/C, but I really like having the vents. If I had access to a shear and bead roller I'd be tempted to fab up something on my own.
~ Craig
1958 Viking 4400
"The Book of Thor"
1960 Chevrolet C10
"A Family Heirloom"
TUTS 59 #1502260 05/26/2023 5:44 PM
When I was working on the passenger side inner cowl of my truck (1953 3100), I made a crude adapter for a small cowl vent. The opening is actually for the optional fresh air heater, which I do not have. So, instead of just putting the block off plate in the truck, I got a used, small vent (can't remember the make or model of car it came from) cut some sheet metal stock and made my adapter. It fits in the truck and the vent will work just fine. My point is that you might be able to do something similar if the cost of replacements is too much. Just a thought.
Mike
1953 3100
The Gray Ghost
My Project journal
I like your idea Gray Ghost.. I have a 54 3100 with the block off panel on the right that was for the heater I guess.. but looking at all the sites they are 55-67 for fit.. so may just find a vent and install it on the cover plate.
Thanks for the idea.
1954 Chevy 3100
One problem solved doesn’t seem to shorten the list
Montgomery, AL
In Project Journals
Crusty Old Sarge
Crusty Old Sarge
Could you post some pictures of what you have done? I sounds like something that would work well.
~ Craig
1958 Viking 4400
"The Book of Thor"
1960 Chevrolet C10
"A Family Heirloom"
TUTS 59 #1502793 05/30/2023 3:32 AM
5 Online: Content
Craig, here's another thought about this. I rebuilt both side vents on my cab but could never get them to completely seal with the vent closed. I ended up blocking off the driver side completely and left the passenger side functional. Like you, I have AC so only use the vent in moderate weather. The passenger side provides all the fresh air I need. You will probably still want to repair the rust but it does not have to be perfect if you do not plan to use the vent flapper door.
Mark
TUTS 59 #1502869 05/30/2023 7:53 PM
Hey Everybody,
Attached are a few pics of my vent and adapter. The first shows the pieces, the second assembled and the third test fit in the truck while I was working on the sheet metal replacement. I had to make the adapter in 2 pieces because of the hinge design on the vent. The vent is from a Volvo 240. I chose this one because it operates with a handle, not a cable and it is small enough to fit within the footprint of the fresh air heater block off panel. I chose to make an adapter instead of cutting up an original block off plate. If some future owner hates it, they can replace the vent with the original block off plate. It was a first attempt that I stuck with, even with the warts. Hopefully there is something here that spurs a thought for you all and helps.
Mike
1953 3100
The Gray Ghost
My Project journal
