6 members (DavidBraley, Maybellene, Gray_Ghost, Otto Skorzeny, Paul Mullen, Gdads51), 98 guests, and 6 robots.
Topics128,185
Posts1,057,200
Members48,465
#1501400 05/19/2023 5:40 PM
I am wanting to change out my steering wheel on my 1940 Chevrolet Truck with a 1953 Chevrolet Bel-air steering wheel and keep the stock steering column. Has anyone done this and if so what did it take to accomplish? T.I.A.
NwRaindevil,
Just a note that I have moved your post to the Interiors forum as the better place to have this conversation.
Am sure some folks will be along soon to provide some replies and helpful info.
Dan
~ Dan
1951 Chevy 3 window 3100
O Online: Content
Basically you just have to make sure the shaft diameter is the same and that the splines on both wheels are the same.
It's pretty easy to take the wheel off so take it off and compare the two. You'll know right away whether the new one will fit.
1950 Chevrolet 3100 (Ol' Roy)
Moderator, Electrical Bay
You probably already know this but there is a steering wheel puller which is merely a 1/4" thick piece of steel with two non-threaded slots and one threaded hole in the center. You screw the proper bolts into your steering wheel (feed them through the slots in the puller), tighten so the thing sits level and then screw in the center bolt. It pulls the wheel off neat as anything. Then to replace it, make certain your wheels are pointed straight ahead, put the wheel on in the proper orientation and tighten the nut/lock washer. Don't lose your horn connecting piece in the process...
~ Jon
2 Offline
I made that puller from scrap metal in high school
Still have it today, it was a long time ago
And if the steering wheel is so stuck on and rusted
And you fear stripping out the bolts or twisting them off
Once it’s all tight under pressure
Hit the center bolt hard with a hammer and it will pop loose.
-s
Thank you for the advice on removing the steering wheel. I was hoping to find out if someone has done this already and how it worked out. I most likely will purchase the 1953 Steering wheel online so I wanted confirmation that it would work before I purchase. I like the idea about the steering wheel puller tool.
ODSS President
ODSS President
I can't say for a 1940. I just replaced my '49 truck steering wheel with a 1952 Chevrolet car steering wheel and it works great. Pay particular attention as to the plastic hub of the '53 wheel, it pries off gently. Note the screws holding the horn ring and the contact pieces underneath, they have to be assembled in order so take picture notes. Disconnect battery or you might get intermittent horn sounds.
~ Cosmo
1949 Chevy Half Ton
Moderated by  ndkid275, Phak1
