0 members (),
109
Mod | | | Forums66 Topics128,183 Posts1,057,194 Members48,465 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2023 Posts: 13 'Bolter | | 'Bolter Joined: Jan 2023 Posts: 13 | I am wanting to change out my steering wheel on my 1940 Chevrolet Truck with a 1953 Chevrolet Bel-air steering wheel and keep the stock steering column. Has anyone done this and if so what did it take to accomplish? T.I.A. | | | | | Joined: Sep 2009 Posts: 6,018 Gearhead, Stovebolt Tech and Parts Tracker, Mod for Swap Meet and GTT | | Gearhead, Stovebolt Tech and Parts Tracker, Mod for Swap Meet and GTT Joined: Sep 2009 Posts: 6,018 | NwRaindevil, Just a note that I have moved your post to the Interiors forum as the better place to have this conversation. Am sure some folks will be along soon to provide some replies and helpful info. Dan
~ Dan 1951 Chevy 3 window 3100Follow this story in the DITY Gallery"My Grandpa Carl's Truck and How it Became Mine"1966 Chevelle (Wife's Hot Rod) | 2013 Chevy Silverado (Current daily driver) US Army MSG Retired (1977-1998) | Com Fac Maint Lead Tech Retired (1998-2021)
| | | | | Joined: Oct 2021 Posts: 6,956 'Bolter | | 'Bolter Joined: Oct 2021 Posts: 6,956 | Basically you just have to make sure the shaft diameter is the same and that the splines on both wheels are the same.
It's pretty easy to take the wheel off so take it off and compare the two. You'll know right away whether the new one will fit.
1950 Chevrolet 3100 (Ol' Roy)
| | | | | Joined: Mar 2014 Posts: 4,510 Moderator, Electrical Bay | | Moderator, Electrical Bay Joined: Mar 2014 Posts: 4,510 | You probably already know this but there is a steering wheel puller which is merely a 1/4" thick piece of steel with two non-threaded slots and one threaded hole in the center. You screw the proper bolts into your steering wheel (feed them through the slots in the puller), tighten so the thing sits level and then screw in the center bolt. It pulls the wheel off neat as anything. Then to replace it, make certain your wheels are pointed straight ahead, put the wheel on in the proper orientation and tighten the nut/lock washer. Don't lose your horn connecting piece in the process...
~ Jon 1952 1/2 ton with 1959 235 | T5 with 3.07 rear end
| | | | | Joined: Aug 2018 Posts: 1,004 'Bolter | | 'Bolter Joined: Aug 2018 Posts: 1,004 | I made that puller from scrap metal in high school Still have it today, it was a long time ago And if the steering wheel is so stuck on and rusted And you fear stripping out the bolts or twisting them off Once it’s all tight under pressure Hit the center bolt hard with a hammer and it will pop loose. -s | | | | | Joined: Jan 2023 Posts: 13 'Bolter | | 'Bolter Joined: Jan 2023 Posts: 13 | Thank you for the advice on removing the steering wheel. I was hoping to find out if someone has done this already and how it worked out. I most likely will purchase the 1953 Steering wheel online so I wanted confirmation that it would work before I purchase. I like the idea about the steering wheel puller tool. | | | | | Joined: Jan 2001 Posts: 1,425 ODSS President | | ODSS President Joined: Jan 2001 Posts: 1,425 | I can't say for a 1940. I just replaced my '49 truck steering wheel with a 1952 Chevrolet car steering wheel and it works great. Pay particular attention as to the plastic hub of the '53 wheel, it pries off gently. Note the screws holding the horn ring and the contact pieces underneath, they have to be assembled in order so take picture notes. Disconnect battery or you might get intermittent horn sounds.
~ Cosmo 1949 Chevy Half Ton Rocinante, like Don Quixote, he is awkward, past his prime, and engaged in a task beyond his capacities. "...my good horse Rocinante, mine eternal and inseparable companion in all my journeys and courses." ...Don Quixote, Cervantes "If you come to a fork in the road, take it."...Yogi Berra "Rudeness is the weak man's imitation of strength." ...Eric Hoffer
