| | | Forums66 Topics128,258 Posts1,058,083 Members48,482 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2022 Posts: 7 'Bolter | | 'Bolter Joined: Feb 2022 Posts: 7 | Where do you buy your rebuild parts for the classic radios? Does anyone sell a rebuild kit with all the common tubes and vibrator that should be replaced when working on these? Thx for the input. | | | | | Joined: Oct 2021 Posts: 7,010 'Bolter | | 'Bolter Joined: Oct 2021 Posts: 7,010 | Atwater Kent Temp sending units, coils, fuel sending units, tube radios, vacuum advance, voltage regs 12 Jacques Street Worcester, 1920s to 1970s (mostly 30s, 40s, 50s) MA, 01603 (508)792-9500 http://www.mykmlifestyle.comKlaus Wojak Electric and vacuum radio antenna parts and rebuilds 241 Hanging Rock Estates Ln. Banner Elk, NC 28604 828-898-9338
1950 Chevrolet 3100 (Ol' Roy)
| | | | | Joined: Aug 2017 Posts: 671 'Bolter | | 'Bolter Joined: Aug 2017 Posts: 671 | Also: Antique Electronic Supply www.tubesandmore.comIn Arizona. Don't think they have "kits" . Confirm your radio model number and you can figure the exact tube & vibrator part numbers. I also ordered a few parts from E-Pay.. But be careful on Tubes! PS Truckernix "Fred" helped me out tremendously on my 1950 6 volt radio!! Todd
1950 Chevy 3100
| | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | Those are some interesting contacts. I use Antique Electronics Supply for some tubes, Just radios for capacitors and resistors and lately I ordered some hard to get tubes from The Tube Store in Hamilton Ontario, Canada. I have bought some ancient tubes on Ebay. I am not aware on anyone selling a kit. | | | | | Joined: Aug 2018 Posts: 1,004 'Bolter | | 'Bolter Joined: Aug 2018 Posts: 1,004 | You asked for all the easy parts Tubes, vibratory and capacitors and resistors no problem
When you need the switches and the dial face parts and the transformers that’s difficult Just ping this forum and I’m sure someone can hook you up There are many ways to fix the original parts so no matter how bad you think they are don’t do more damage when taking the radio apart and between me and truckernix I suspect any radio part can be sourced.
Are you restoring the OEM USA radio or the OEM Canadian Autoradio unit? Or is it an aftermarket model? -s | | | | | Joined: Feb 2022 Posts: 7 'Bolter | | 'Bolter Joined: Feb 2022 Posts: 7 | Wow, thank you for all the leads. The radio is model 2233029. I have never worked on these old radios, but plan on starting by replacing the vibrator and capacitors | | | | | Joined: Aug 2018 Posts: 1,004 'Bolter | | 'Bolter Joined: Aug 2018 Posts: 1,004 | I suggest you at least measure the resistors as you go The old carbon ones can change value and I’ve seen some way out by more than tolerance I recommend you use metal foil type in the tube radio as they like operating hot and are low noise Don’t replace the rectangle 6 color dot mica capacitors Those will be good
Oh and if your search on here I posted some photos and details about fixing a radio, might be helpful -s | | | | | Joined: Feb 2022 Posts: 7 'Bolter | | 'Bolter Joined: Feb 2022 Posts: 7 | Great. Thank you! Hope to start digging in this weekend. | | | | | Joined: Feb 2022 Posts: 7 'Bolter | | 'Bolter Joined: Feb 2022 Posts: 7 | Simple question, can you even put a gmc radio in a Chevy truck? Isn’t one positive ground and the other negative? | | | | | Joined: Oct 2021 Posts: 7,010 'Bolter | | 'Bolter Joined: Oct 2021 Posts: 7,010 | Most electrical stuff doesn't care what part of the circuit is grounded. Voltage is the main concern.
| | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | I don't know which year the question is related to. However in the years that used tubes and vibrators, if the vibrator is the mechanical style as in the original radio, the polarity does not matter. However if the vibrator has been replaced with a modern solid state unit, the polarity of the vibrator must be correct. | | | | | Joined: Feb 2022 Posts: 7 'Bolter | | 'Bolter Joined: Feb 2022 Posts: 7 | This is a gmc 2233029 radio I am wanting to put in my 1951 Chevy 3600. I K assuming it is original but am just starting to tear it apart. Currently it does nothing under power. Thanks for all the help.
| | | | | Joined: Aug 2018 Posts: 1,004 'Bolter | | 'Bolter Joined: Aug 2018 Posts: 1,004 | The non synchronous vibrator type used in the 47-53 gmc and Chevy truck radios in the USA do not care about polarity Your radio can swap between ground types.
The synchronous vibrator used in the Autoradio model 490 for for 47-49 trucks in Canada does care about polarity and there is a warning label indication to swap the rotation of the vibrator according to the ground type Later Autoradio changed their circuit to the non synchronous style by the model 510 and added an 0Z4 so the 1951 and later radio could interchange without that detail. I forget off hand the model 500 was between those two.
Source: I have all these radios in my collection and original documentation.
-s | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | Wow I didn't know that synchronous vibrators were still around in the late forties. How long do those last in service? | | |
