4 members (55shaker, IHPWR, Otto Skorzeny, 1 invisible), 76 guests, and 2 robots.
Topics128,026
Posts1,055,403
Members48,422
#1499645 05/05/2023 10:57 PM
I got a question, anybody using a shock bar. I have installed a 1969 12 bolt truck rear end and I need to connect my shocks. All pictures and suggestions will be thoughtful.
ThanksTom
O Online: Content
What's a shock bar? Is that another name for an anti-sway bar?
1950 Chevrolet 3100 (Ol' Roy)
I have seen shock bars for unibody vehicles, but never for one with a frame.
That is assuming you mean a bar to connect the tops of the shocks and keep them from being able to wobble independantly (like the more common strut bars).
If you mean an anti-sway bar, there are many choices available.
From the Rocky Mountains?
Check in with the RM Bolters!
HiPo Forum Moderator
1958 Task Force Truck
Follow in the DITY Gallery
1959 3200 Task Force
The Ballad of Enkidu
Insomniac
Insomniac
I assume that this is a followup to this post. https://www.stovebolt.com/ubbthread...20/replacement-rear-end.html#Post1472020
OP is putting a new rear end in a 1950 3100.
I installed a 10 bolt Camaro rear end. My shocks are mounted to the frame with heavy angle iron. Use the heavy stuff - not bedframe material!
Gord 🇨🇦
1954 1/2 ton 235 4 speed
Is this what you had in mind? This came with a 1954 parts truck I bought but I did not need it. It is 2” thick wall tubing with end plates welded on both sides. Small thick spuds with holes for 7/16-inch bolts to mount the shocks pass through the main tube. The spuds are welded on both sides of the tube. The shock bolts are located 8 inches from each side and 28 inches between. Total 44 inches wide. I have not tried to fit it on a truck. You may have to adjust to fit your year truck. I believe it bolts between the frame rails above the new rear axle with ½ inch bolts[img]http://[/img][img]http://[/img]
1954 Chevy 1300 engine 235 (1959)
1955 (first series) Chevy 3100 engine 261 (1957)
1927 (other brand) Model T- engine 327 (1968)
The tube shock mount and shocks pictured in my previous post are not for sale. Only responding to the OP’s initial question.
No1300 #1500174 05/09/2023 11:19 AM
Yes sir, that is what I had in mind.
Gord&Fran #1500567 05/12/2023 11:57 AM
Like your idea
Gord&Fran #1500674 05/13/2023 3:52 PM
Gord do you have any pictures of your rear shock set up. Did you weld the angle to a block of square tubing
Insomniac
Insomniac
Welded the angle to an angle. Other end of the shock mounts to plate from donor car. Picture attached.
Gord 🇨🇦
Gord&Fran #1500756 05/14/2023 4:18 PM
Gord thank you sir. I thought you might have done that. Much appreciate you help.
Tom
