| Crusing in the Passing Lane Joined: Jun 2011 Posts: 5,096 | I believe the early gearbox has a slightly smaller bolt pattern, bottom right not offset like 420 has. Drill new mounting hole in bellhousing. Verify first of course.
Ed
