5 members (6inarow, fonz8261, greenie-reddy, klhansen, Oswald), 76 guests, and 1 robot.
Topics128,035
Posts1,055,549
Members48,425
Page 2 of 2 1 2
I have definitely seen worse on running motors.
Mike
The plan is to just replace the rod bearings for now and keep the main bearings in. That way I don’t have to pull the engine and can enjoy it this summer. Then budget for a full rebuild next year.
The back side of the thrust bearing will be polished from the clutch fork pushing the crank forward every time you shift. That's normal, as long as the end play isn't excessive. If it's got .010" or less end play, no problem, and I've seen engines with a lot more.
I measured one of the journals at the front and one at the back of the engine. The front one is 2.3010 and the rear is 2.3016. Based on this what bearing size do I need? measured all 6 and they were between 2.3010 and 2.3016
Crap now I am wonder if I an reading the gauge right. the number showing is 3 and the number on the dial is on 10 perfectly on 4 of the journals.
On the other it is on the 3 and the dial is right above the 10 so I go with 10 and then the next number to line up is the 6. So maybe it should be 2.31 and 2.316 hmmm
Ok, I watched a YouTube video and see it should be 2.310 I think the one I got at 2.316 was me or the tool since all the others are 2.310
It looks like you'll need a set of .002" undersize bearings, assuming all the journals are still round, and have the same amount of wear. "Measure twice- - - -order bearings once!"
Page 2 of 2 1 2
