5 members (Stovebolt48, 51sub, Wayne67vert, Otto Skorzeny, 1 invisible), 89 guests, and 2 robots.
Topics128,041
Posts1,055,593
Hi
What is the thread for the hole in the side of the intake for the fitting for the wiper vacuum line
AD Addict & Tinkerer
GM used several different sizes. There all pipe threads, so your best bet is to remove what was installed and size it up or alternately, you can measure the hole. Measure as good as you can the outer dimension of the threads as the difference in pipe sizes is big enough to measure the difference with a ruler.
Here is a chart that you can compare sizes. Remember you are measuring the OD of the threads.
Phil
Project Journals
Stovebolt Gallery Forum
Thank you!
