3 members (klhansen, 2-Ton, Uncles51), 54 guests, and 1 robot.
Topics128,041
Posts1,055,481
Members48,424
#1496949 04/18/2023 12:53 AM
I started hand sanding the bedwood early on Friday morning and rolled on the final coat Sunday night at 10pm! It’s finally finished and now I know why I’ve put this off since 2014!!! I brushed on 3 coats of POR15 and then rolled on 2 coats of exterior latex. Did a little mock up this morning with the polished stainless strips
That' looks awesome!!
1953 Chevy 3100 1/2 Ton Pickup
Doug
Looks great to me.
From the Rocky Mountains?
Check in with the RM Bolters!
HiPo Forum Moderator
1958 Task Force Truck
Follow in the DITY Gallery
1959 3200 Task Force
The Ballad of Enkidu
Does look great! Would be great to know the long term durability compared to the MAR-K research results. See their testing report on their website, if interested.
Thanks Guys
MarK is where I got the idea back in ‘07 or’08, I’m sure mine will last much much longer as our driving season is about 5 months long and she’ll likely never spend a night outdoors!!
I didn't know that POR15 could be used on wood.
I would have used an oil based primer on all 6 sides and then applied the acrylic latex after letting the primer dry for a week.
1950 Chevrolet 3100 (Ol' Roy)
I reviewed the Mar-K finish reports and considered Por-15 but decided to use Smith & Company epoxy sealer follwed by a spar varnish. It is still a work in process given all the coats on all the surfaces but the attached shows the bottom side after the last (I think) coat of varnish.
Our driving season is a little longer than 5 months, maybe 8 dependingon the year, but like you I don't anticipate my truck sitting outside often.
1949/50 3600 Project
Follow in Project Journals
I put 2 coats of cheap satin black exterior house paint on my homemade cheap pine setup and i use it often and its held up great. Wayyy better than I thought and its been over 2years. I have moved bikes, quads, sleds, transmissions, wheels, pellets and lumber all the time. I was careful with it at first but now I dont even care and it blends in with rest of truck.
Got the box back from paint at the end of June and finally just cleared out enough room in the shop to assemble it this weekend!
Eventually the cab and doors will return from paint and “real” assembly can begin!!
The beige is called “Sahara Beige” and was the original colour of my truck in ‘53, I asked the paint shop for a dark blue that “popped” with no metallic, i saidI trusted their judgement since they are experts and I think they nailed it!!
Nice!! It's good to see some progress. thumbs_up
Yep, 2 coats of POR-15 rolled and 2 coats of rattle can POR top coat. The POR-15 cures hard, but while just tacky top coat applied. I did top and bottom.
Last edited by Gdads51; 11/19/2023 11:11 PM. Reason: remove pic link from text box
~ BD.
1958 Apache Stepside
1958 Apache 1/2 ton Panel
1959 Apache 1/2 ton Panel
(https://www.mar-k.com/PDFs/Instructions/woodtest2.pdf
Three coats of POR-15 Rust Preventative Paint as a seal coat and three coats
of Behr gloss black enamel.
This finish is on an oak sample and it has no failure
at this time.
The finish has possibly dulled slightly, but is still very glossy and
sealed well.
The finish has lasted much better than the first test series in which
we used Behr primer and topcoated with the same Behr gloss black enamel.
Even though POR-15 Rust Preventative Paint is not specified for wood by the
manufacturer, it appears to be an effective primer if it is coated with a quality
topcoat paint.
If you plan to paint your bedwood, this finish system should be
considered as it is very durable and easy to apply.
RLB Offline
Very nice!
1966 C-10 Short Stepside
HiPo
Step-by-step ~ and on-going resto build
in the Project Journals
AD Addict & Tinkerer
Love the blue! Really pops against the Sahara Tan. Nice job!
Phil
Project Journals
Stovebolt Gallery Forum
Did I miss it, or what's the name of the Dark Blue? Looks very nice with the Beige.
David
I don’t think there’s a name for it
I asked the body shop to concoct a dark blue with no metallic in it that “popped” with the beige!!
They did a fantastic job. It looks great!
