0 members (), 35 guests, and 3 robots.
Topics128,014
Posts1,055,327
Members48,419
#1496308 04/12/2023 7:29 PM
I have 12 NOS solid lifters in an original GM box. The end of the box that had the part number is missing. The lifters are the new style. (not the milk bottle type). The push rod seat is a solid machined smooth dip in the top with a relief machined in the side. Hand writing on the box indicates they are a two piece; a separation line appears about 1/4” from the bottom. They are the correct diameter; however, they are approximately .0962” shorter than other lifters I have. The short lifter is 2.188 inches tall and other lifters I have are 2.315 inches. (measured with dial caliper) Was there a change in the design over the years? Can this short lifter be used in my 261?[img]http://[/img]
1954 Chevy 1300 engine 235 (1959)
1955 (first series) Chevy 3100 engine 261 (1957)
1927 (other brand) Model T- engine 327 (1968)
No1300 #1496310 04/12/2023 8:06 PM
H Online: Content
Ignore the overall height of the lifter body. Figure out a way to measure the distance from the bottom of the lifter where it contacts the camshaft to the depression where the pushrod fits. If it's the same, or close on both types, use the same pushrods. If not, acquire some pushrods that compensate for the height difference. There's a company that I linked to in another post that will fabricate new pushrods of any length and end dimensions that you specify.
www.pushrods.net/
No1300 #1496360 04/13/2023 4:09 AM
As suggested by Hotrod Lincoln I measured the distance from bottom of lifter to bottom of the pushrod depression. That distance is very close to being the same on both lifters. Question answered, thank you. Different in appearance but function the same.
No1300 #1496361 04/13/2023 4:13 AM
Does anyone have a GM part number for 1957 to 1962 solid lifters?
No1300 #1496363 04/13/2023 4:30 AM
Link
No1300 #1496368 04/13/2023 5:03 AM
Please note that "very close" is not "the same". I would strongly recommend verifying your combined lifter/pushrod length is correct before running this setup. It doesn't take a lot of error there to kill a pretty hard/expensive to replace cam.
From the Rocky Mountains?
Check in with the RM Bolters!
HiPo Forum Moderator
1958 Task Force Truck
Follow in the DITY Gallery
1959 3200 Task Force
The Ballad of Enkidu
No1300 #1496396 04/13/2023 1:58 PM
Kevin's info is spot on for the original part number on the solid lifter in question from the 1929-57 Parts Catalog.
The 1958 Chevy Master Parts Catalog provides the added info that GM# 5231445 was replaced by GM# 5231800 as of 3-1-58 (see links 1 & 2 below).
The later 1979 Chevy Master Parts Catalog indicates the correct GM# 5231880 (not 5231800) applies to your '57 engine (same for 235 or 261).
http://www.gmpartswiki.com/getpage?pageid=210786 (See note with 3rd link below for error info)
http://www.gmpartswiki.com/getpage?pageid=211286 (See note with 3rd link below for error info)
http://www.gmpartswiki.com/getpage?pageid=21163 - Apparently the 1958 Catalog had a typo as the later 1979 Catalog indicates GM# 5231880 is the correct one for ALL 235/261 6 Cyl '56-'62 + '63 w/4WD with the added detail "(2-3/16" long-two piece)".
Hope this is clearer than mud???
Dan
EDIT: The 2-3/16" length measurement specified in the '79 Catalog converts to 2.1875 (within 0.0005 of your original measurement of the "short" lifters).
~ Dan
1951 Chevy 3 window 3100
Fibonachu #1496397 04/13/2023 2:30 PM
H Online: Content
Originally Posted by Fibonachu
[quote=No1300]Please note that "very close" is not "the same". I would strongly recommend verifying your combined lifter/pushrod length is correct before running this setup. It doesn't take a lot of error there to kill a pretty hard/expensive to replace cam.
Why is there close to 1/2" of travel available on the rocker arm adjusting screw, then? Getting obsessive/compulsive about an irrelevant manufacturing tolerance is sort of like lying awake at night wondering why the kitchen sink faucet isn't dripping.
Note that I said to verify that the combined length is correct. I did not say it would not work.
I don't know what the old-timey expert way to verfiy that is, but I would do it by ensuring that there is sufficient adjustment in the arms to set it up properly.
Given no actual data on the measurements, I hold by the recommendation to not just assume they are close enough without verifying it.
Then again, I am the guy that measures the new cam and pistons that I got from Summit to make sure they are actually in spec before I install them. Overkill? Usually. But I have found more than one new part to be out of spec before I installed it.
No1300 #1496410 04/13/2023 5:55 PM
Thanks Gdads51 that was exactly what I needed. I an on to next thing!
No1300 #1496412 04/13/2023 6:10 PM
H Online: Content
I degree every cam I install to verify that the lobe profile matches the timing card. If it doesn't suit me, I come up with a combination of parts that does. That might include using parts from several manufacturers in the same assembly. I rebuilt an air cooled Volkswagen engine with "big bore" cylinders and pistons using flathead Ford V8 piston rings and Corvair wrist pins, and ran it over 70K miles that way.
No1300 #1496421 04/13/2023 8:28 PM
Glad it was helpful! thumbs_up
Movin' on. grin
Dan
~ Dan
