4 members (dwreills, Gdads51, Otto Skorzeny, 1 invisible), 105 guests, and 3 robots.
Topics128,036
Posts1,055,460
Members48,422
#149623 12/22/2006 5:03 PM
...what brake fluid should i use in my '65 C60, will DOT3 be fine or is there a special fluid i need to use? on a sidenote....what size brake line runs to the rear axle? I bought 3/16" but it looks smaller than whats on the truck, but the next size up at my local parts store is 1/4"
#149624 12/22/2006 7:28 PM
badtexasz28,
I think you will find that DOT3 and DOT4 are fine alone or together. Don't mix any DOT5 in there..it is different and will not mix.
Stuart
#149625 12/22/2006 10:00 PM
Thanks Stuart, I had a sneaky suspicion that I could get away with DOT 3 (plus I have 3 or 4 jugs of it on hand)
Now can anyone tell me what size brakelines are supposed to be original going to the rear of the truck?
#149626 12/22/2006 11:32 PM
Normally, the line running down the frame rail is 1/4", and the ones going from side to side will be 3/16". That's what my 59 model 3800 has, anyhow!
#149627 01/08/2007 8:05 AM
1967 shop manual says; use delco #11 hydraulic brake fluid or equivelant when servicing brakes. This brake fluid is satisfactory for any climate & has all the qualities necessary for operation, such as "high boiling point" to prevent vapor lock & the ability to remain fluid at low temprature.
"Hope this helps".
CFFC
Don
