| | | Forums66 Topics128,030 Posts1,055,430 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2006 Posts: 63 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2006 Posts: 63 | ...what brake fluid should i use in my '65 C60, will DOT3 be fine or is there a special fluid i need to use? on a sidenote....what size brake line runs to the rear axle? I bought 3/16" but it looks smaller than whats on the truck, but the next size up at my local parts store is 1/4" | | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | badtexasz28,
I think you will find that DOT3 and DOT4 are fine alone or together. Don't mix any DOT5 in there..it is different and will not mix.
Stuart | | | | | Joined: Dec 2006 Posts: 63 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2006 Posts: 63 | Thanks Stuart, I had a sneaky suspicion that I could get away with DOT 3 (plus I have 3 or 4 jugs of it on hand)
Now can anyone tell me what size brakelines are supposed to be original going to the rear of the truck? | | | | | Joined: Feb 2004 Posts: 29,749 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,749 | Normally, the line running down the frame rail is 1/4", and the ones going from side to side will be 3/16". That's what my 59 model 3800 has, anyhow! Jerry
| | | | | Joined: Jan 2007 Posts: 63 New Guy | | New Guy Joined: Jan 2007 Posts: 63 | 1967 shop manual says; use delco #11 hydraulic brake fluid or equivelant when servicing brakes. This brake fluid is satisfactory for any climate & has all the qualities necessary for operation, such as "high boiling point" to prevent vapor lock & the ability to remain fluid at low temprature. "Hope this helps".
CFFC Don | | |
