Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
3 members (Guitplayer, Jason Davies, TUTS 59), 121 guests, and 9 robots.
Topics128,281
Posts1,058,476
Members48,490
Page 2 of 2 1 2
How about the inertia starter on a Stearman? Crank the handle about 100 revolutions to wind up a spring, then get a big flywheel spinning and engage a clutch to spin the prop. Then there was the shotgun shell start on some of the big radials.
www.youtube.com/watch?v=fNARZLVEYYE
Coffman Starter
1950 Chevrolet 3100 (Ol' Roy)
2 Offline
I had a lawnmower like that
You hand crank up the spring then turn a knob to let it go and hopefully it would start
Fun times
Man I hated mowing the farm lawn
-s
Truckrolet A friend had a 1946 Aronca champ hand crank airplane,we'd chain it to a utility pole,start it,hold the brakes take off the chain,fly !!
Carburetion specialist
Never cranked a Chevy; but in a different lifetime before I was bitten by the "buy American" bug, I hand-cranked a number of British sports cars, and before that lots of tractors.
The British cars all had electric starters, so it wasn't necessary, but the looks from bystanders were fabulous!
To add to Jerry's comment about cranking only 1/2 turn (or less) and cranking up (ALWAYS), not down; do not wrap your thumb around the crank handle. Hold the crank in your palm, with four fingers, and your thumb should be under the crank, never wrapped around it. I was taught this on cranking tractors 65 years ago. I do not remember anyone that had a bad experience if the engine were cranked correctly.
Jerry - it wasn't Lucas cranks that didn't work in the rain; it was older Plymouths. It was common knowledge in north central Missouri 65 years ago that an older Plymouth wouldn't start if a dog lifted his leg against a tire! Maybe 30 years ago, a Plymouth enthusiast found the mounting of the coil was in a spot where condensation from the hood would drip on the coil terminals, shorting it out. Moving the coil fixed the problem.
Jon
The Carburetor Shop
Originally Posted by Otto Skorzeny
What happened to the link to the picture of the handle with the dimensions? It seems to have disappeared.
Apparently buoymaker(?) deleted it. ohwell
Anyway, HERE is a link to Denny's picture with dimensions.
Jon
Did you grow up in north central Missouri, carbking? My hometown is Trenton.
1951 3100
Page 2 of 2 1 2
