0 members (), 191 guests, and 2 robots.
Topics128,089
Posts1,056,141
Members48,436
#1495217 04/04/2023 4:29 PM
I thought 216’s had poured Babbitt bearings mains and rods mine has inserts maybe it’s healthier than I thought just have the pan of to do rear main rope seal and check tolerances.
Same answer as in your other thread- - - -216's have insert type main bearings and Babbit rods, unless the rods have been machined for an aftermarket insert bearing.
Thanks haven’t made it that far yet it’s pretty clean inside and cylinders still have cross hatch hardly any vertical lines someone has been through it before
Back in the dark ages, I actually bought a set of insert bearing rods from NAPA. They were reasonably available and routinely replaced apparently. I think you got lucky with that engine
1946 1-ton Panel
1952 1-ton Comml. W/Grain Body
