3 members (KEVINSKI, Bill Hanlon, JW51), 229 guests, and 1 robot.
Topics128,101
Posts1,056,180
Members48,436
Page 2 of 6 1 2 3 4 5 6
Originally Posted by Phak1
Do you have a engine lift and a buddy (or rental) with one too? You could use two, one from the drivers or passengers door and one from the back using a couple of 4x4’s fastened to the end of the boom and passed thru the windows.
Thats a thought. thanks
~ BD.
1958 Apache Stepside
1958 Apache 1/2 ton Panel
1959 Apache 1/2 ton Panel
Bout there
~ BD.
~ BD.
Also wanted thank especially, Dan at Advanced Engine Concepts for
coming out to the house and helping me with my project. Best engine guy in this area.
~ BD.
Quick description. .1959 Panel Apache
~ BD.
Will I have any problems running dual exhaust to the rear of this panel? The gas tank location
looks concerning.
~ BD.
Image didn't load correctly?
1949/50 3600 Project
Follow in Project Journals
I guess right at the time of host providing.
~ BD.
My engine arrived. Thinking how best to get around gas tank
with exhaust pipes.
~ BD.
Looks like 2 into 1 rather than dual exhaust would make things a lot easier. If you are set on dual exhaust your going to need to cross over twice, once near the transmission and once behind the rear axle.
2 into 1 sounds good to me.
~ BD.
I got the engine in. Put it in the 1959 Apache.
M-22
~ BD.
Looks like you are making good progress.
I am, but now I need to put in the hurst shifter and linkage. Cut hole.
~ BD.
Seats are in. Trany and shifter/linkage hooked up. Should be able
to crank her up soon. Shout out to Dan Timm for helping me with the 327!!!
https://www.facebook.com/TimmMotorsports/
~ BD.
That's great progress.
I am sure it will be a banner day when you get the engine fired up.
Yep, getting close. Here is what I used for the exhaust.
Heat shields.
~ BD.
Wow awesome job. One thing caught my eye, something about silicone sealer? Never use that on a body, it won't last paint won't stick to it. Always use a seam sealer instead.
Latest pic. Recently replaced license plate light on back door.
~ BD.
Looking good!
Nice to get all the brake work done.
~ BD.
License light
~ BD.
Took this lull as an opportunity to paint the floor.
Still needs 1 more coat. I was thinking about a clear top coat.
Its an oil based paint. What`s a good choice?
EDIt.. I think I`ll use this. I have a couple quarts.
~ BD.
Of cousre there is not a set of these precut available.
I made a set for a short bed stepside(7)strips work.
Only needing 5 I had 2 to cut up the for the fill.
I was able to match up 3 factory hole spacing. Not quite finished.
Just took the time to take this pic.
Little trick.... to keep the bed bolts from pushing up while
your underneath. I used my diving weight belt laid across the top of the bolts.
~ BD.
Looking great!
Thanks!! Soon I hope to be holding title and tags.
~ BD.
bumper on! The driver side is about 1/3 inch too high.
What the best way to adjust that down?
~ BD.
I suspect the bumber bracket bolts to the frame can be loosened and the bracket "adjusted" to lower the driver's side and/or the passenger side higher.
Thats what I was hoping. Thanks!
~ BD.
Looking at my 58 the bumper on this 59 needs to tilt downward more.
To where my finger just can get under to the bumper filler.
~ BD.
I ended up setting the bumper up on crates so it fit level and
where it needed to be in relation to the bumper filler and fenders.
Marked and drilled new holes in the brackets.
I guess the new bumper is not precise.
~ BD.
Bumper level. New tires
~ BD.
Looking good, now if we could just get this winter weather to go away.
Yeah, it looks like I will have to replace at least one front leaf spring.
That'll make 6 total ,if not 7 in less than a year. The front is listing to the driver side.
~ BD.
Guitplayer,
Just an observation, but changing just one leaf spring can create an unsafe condition when driving.
IMO, best choice is to replace both springs on an axle (front or rear) when there is a need. May be a bit more money, but in my book a safe drive is far better than the alternative.
Just my .02 worth.
Dan
~ Dan
1951 Chevy 3 window 3100
I think you are right about that. I always replaced both before F+B .
I was hoping I would not have to this time.
I have 2 fronts that I took off another 59 that had the bottom leaf
flipped to the top and made the truck sloppy and bottomed out.
I flipped them back to underneath and wondering if they may work.
I put new ones to replace them.
~ BD.
here are the 2 springs I have. They might still be good.
Maybe someone has one they can measure upside down like this to see
if mine are really worn. It is at 6 1/4 inches at the arch.
I like the idea of using these being they may be slightly worn and
not too stiff. New ones are really stiff new.
~ BD.
Guitplayer,
Attached are some screen shots of data I was able to find in a web search on "specs" for the '58 front springs (found at https://www.truckspring.com/) that may help you confirm these springs are correct for your planned use. I used the original GM Part Number "3719560" from a Chevy Master Parts Catalog and your vehicle info to help locate these tidbits.
Also included their diagram on how/where to take measurements of your springs to help compare with the listed spring specs. If you remeasure your springs and the numbers match these specs (A and B lengths, width, spring stack thickness and Arch height) you may be able to ring the "winner-winner-chicken dinner bell". (Just an educated guess on my part.)
Let us know what you figure out. headscratch
Dan
PS: Also included a snap of the rear spring data in case you may need that down the road.
~ Dan
Very nice!!!! Thanks. I will check that tomorrow. Its for my 1959
but should be the same as 58.
Hopefully it will save me some money.
~ BD.
I just went ahead and ordered new front springs.
Its too much work for me to gamble on an unsurity.
~ BD.
Moderated by  Phak1
