Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
4 members (MNSmith, dt235sd, J Lucas, Hotrod Lincoln), 199 guests, and 6 robots.
Topics128,288
Posts1,058,579
Members48,492
Apprentice
Apprentice
I am in the process of a near frame off restoration of my 1951, 4100, 5 window, flat bed, dump. The question is, should I have the frame dipped, (complete frame off) or should I derust and go with Por-15. The manufacturer contends that when using Por-15, dipping or sand blasting is a waste of time. This truck is not intended to be a trailer queen, I want a show truck in the front and a weekend dump truck, flat bed in the back. Not having to remove the hoist and every leaf spring would be a real time/money saver. If in the end there is no real benifit to completely taking it down, then why should I. Any thoughts would be appreciated.
V
V Offline
I'm not an expert in anything but I suggest you do exactly what you want and think is best. It's your truck and only you know what you really want and will accept. Good luck!
My advice would to clean up the frame the best you can, pressure wash it if you've got one and use Por-15 or a really good primer. Then put on a good semi-gloss or flat black paint. The semi-gloss or flat seems to do a good job hiding imperfections. If you are using it as a dump/flatbed anyways it going to get dirty and messy, so a big $ paint job is going to look the same as a small $ paint job after the first puddle you go through. Just do a carefull and neat job and it will turn out way cool.
1948 Chevy 6400
1964 Chevy 1/2 Ton
I like the John Deere black paint, sticks well w/o primer & it is cheap. Brian
My \'64\'s in the Gallery
Pictures in my Photobucket
1964 C10 Custom Cab 350/700R4
1964 Suburban 350/700R4
1979 Ford F350 4x4 400/c6
Personally, since you're already stripped that far down, I'd blast & paint - unless you're not intending to keep the truck long term. But if you are, an extra 5% of cost & work will give you an extra 50% of job - and once it's on the road,you won't want to strip again in a hurry - do it now, forget it later!
U
U Offline
Hi 51flatbedchev,
It sounds just like what I am currently in the middle of doing. I am just going to clean up the frame, use JASCO to kill the rust, use etching primer for extra protection and then use the smooth black hammerite paint. It is thick and should look good. I too am going to use the truck for show and hauling dirt/machines. Good luck in what ever way you go.
Aloha,
Keoni (1948 1.5 ton loadmaster)
