7 members (klhansen, MNSmith, TUTS 59, Peggy M, Cletus1950, 2-Ton, mick53),
65
Mod | | | Forums66 Topics128,174 Posts1,057,047 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2016 Posts: 12 'Bolter | | 'Bolter Joined: Feb 2016 Posts: 12 | Hey guys. 1954 6400, it has an Eaton two speed floater rear axle. I decided to do a brake check before getting the truck off of the jack stands. I noticed a leak on the RR hub. Pulled the hub apart and bearings seem fine, although, the races look as if someone got a little too happy. I am completely unsure as to why these marks are in the races. Now, with that said, the are not easy bearings to find. Have any of you replaced [img] https://www.stovebolt.com/ubbthread...umber/55181/filename/20230326_182031.jpg[/img]originals with a standard tapered bearing and got away from these factory bearings. As I said, I can find bearing replacements, but not races. The seals I have found also don't seem to measure correctly. My seal measures 4.871, the closest replacement I found thus far is 4.881, that will never go, no matter what size hammer. Any input would be a huge help. | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy Trainmna673, according to my Bower/BCA catalogue the tapered replacements for the Hyatt barrel bearing A11950 are M111048/M111012. The inner hub seal is GM p/n 3708819 that crosses to National 5453, give your supplier your seal dimensions to confirm that number is correct. This information is supplied assuming that the original rear axle is still in the truck, hope that helps. | | | | | Joined: Feb 2016 Posts: 12 'Bolter | | 'Bolter Joined: Feb 2016 Posts: 12 | Thanks so much, this is so helpful! | | | | | Joined: Feb 2016 Posts: 12 'Bolter | | 'Bolter Joined: Feb 2016 Posts: 12 | Got everything apart today this is what I am showing. Outer bearing Hyatt A11950 Outer race Hyatt 11950Y Inner bearing Hyatt 12235Y Inner race, still on rear-end snout, didn't have a chance to remove. Seal is a Victor 49998
The Victor seal 49998 OD measures 4.822" The National 5453 OD measures 4.881" My hub measures ID 4.867"
When I get to the shop this evening I will get some more measurements and keep everyone posted.
Thanks again | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy Trainmna673, Victor 49998 = National 417355. Hyatt 12235Y = set B12235YK whose components are M514546 and M514512, hope that helps. | | |
