8 members (66flea, Southerntruck, Otto Skorzeny, GMCJammer51, Phak1, TGP, DadsFirstPickup, Wayne67vert),
118
Mod | | | Forums66 Topics128,049 Posts1,055,682 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2014 Posts: 3,677 'Bolter | | 'Bolter Joined: Jan 2014 Posts: 3,677 | There are plenty of downsides to this modern world and global economy. But one perk is the instant availability of almost any product you’ve ever dreamed off.
Somehow I came across some heated seat “kits” on Amazon the other day. All sorts of variations. But all consist of a coil heated pad of some sort. Some are designed to sit atop your existing upholstery, and some designed to go UNDER the upholstery.
There is less than a 1% chance I will ever act on it, but it sure looks like it would be super easy to make your seat heated, in a very hidden way, whilst reupholstering your old truck. And it could be done pretty inexpensively.
I’d have to assume someone here has already tried this. How did it pan out?
1951 3100
| | | | | Joined: Oct 2021 Posts: 6,746 'Bolter | | 'Bolter Joined: Oct 2021 Posts: 6,746 | I look at things like that and ask what's the point of driving a 70 year old vehicle?
1950 Chevrolet 3100 (Ol' Roy)
| | | | | Joined: Jul 2000 Posts: 2,189 Insomniac | | Insomniac Joined: Jul 2000 Posts: 2,189 | If you are interested in using modern seats, many have all the features. Fran's car has heated seats and steering wheel; I think it will be a requirement in her next car as she really likes them. See this thread for a discussion on modern seats that fit: https://www.stovebolt.com/ubbthread...772/seats-for-a-52-3100.html#Post1485772
Gord 🇨🇦 ---- 1954 1/2 ton 235 4 speed | | | | | Joined: Jan 2014 Posts: 3,677 'Bolter | | 'Bolter Joined: Jan 2014 Posts: 3,677 | I’m not interested in modern seats. Just interested in a warm butt in a cab that leaks air like a sieve.
Like I said, probably never going to act on this idea. Just sounds like an easy and cheap upgrade if a guy was already in the midst of recovering his old seat.
1951 3100
| | | | | Joined: Nov 1995 Posts: 5,716 62401 | | 62401 Joined: Nov 1995 Posts: 5,716 | When I've driven my '49 in cold weather ("The cab that breathes!" Yay ....), my trusty poncho liner (I never leave home without it) does the trick. A similar smallish blanket would do the same thing.
~ John A kid raised on Hotwheels, Matchbox and Tonka cannot be reasonably expected to own only one vehicle as an adult. 1949 Chevrolet 3804In the Legacy Gallery | In the Gallery Forum1973 IH 1310 Dump1963 Kaiser M38A12001 International/AmTran RE3000 "Skoolie"2014 Ford E-350 4x4 (Quigley) | | | | | Joined: May 2015 Posts: 11,031 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,031 | I don't like heated seats at all. The wife's car has them and if I drive it and she leaves the heat on the drivers seat, I notice it and turn it off in less than a block, even in sub-freezing weather. I value my privates.  We had a Buick with them before the current car and the seat heater relay failed on full heat one time and I drove 15 miles home with my butt suspended above the seat to keep from getting scorched.  A replacement relay was over $200, so the failed one just got pulled out and tossed.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Jan 2014 Posts: 3,677 'Bolter | | 'Bolter Joined: Jan 2014 Posts: 3,677 | Not gonna lie. I like the heated seats in my work truck. The heated steering wheel, too.
1951 3100
| | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | I forgot all about my car having heated seats & strg. wheel till you all just reminded me. I recently moved to a retirement community apartment & my car sets outside. I'll try it next time I go out in a cold morning.
George They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Jan 2014 Posts: 3,677 'Bolter | | 'Bolter Joined: Jan 2014 Posts: 3,677 | I find the heated steering wheel annoying after just a few minutes. But it’s nice when you first start out and the wheel is ice cold. It warms up so quick.
The seats are handy even on days that aren’t that cold but my back is sore. Warm seats make the sore back feel better.
1951 3100
| | | | | Joined: May 2015 Posts: 11,031 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,031 | I wouldn't mind a bit of heat on the lumbar area, but definitely not on the seat bottom, for reasons I mentioned above.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Jan 2014 Posts: 3,677 'Bolter | | 'Bolter Joined: Jan 2014 Posts: 3,677 | I wouldn't mind a bit of heat on the lumbar area, but definitely not on the seat bottom, for reasons I mentioned above.  I think your relay failure crisis has muddied your perceptions. These things are completely adjustable. On the low setting, I can’t even tell the heat is on!
1951 3100
| | | | | Joined: May 2001 Posts: 1,904 'Bolter | | 'Bolter Joined: May 2001 Posts: 1,904 | When it gets to 20 below zero, I'd rather have a heated transmission. That gear lube is like tar when it gets that cold. I already use one of those magnetic 250 W heaters for the oil pan but a 2nd one on the tranny might be nice. 1948 3/4-Ton 5-Window Flatbed Chevrolet 34 Years. Now with a '61 261, 848 head, Rochester Monojet carb, SM420 4-speed, 4.10 rear, dual reservoir MC, Bendix up front, 235/85R16 tires, 12-volt w/alternator, electric wipers and a modern radio in the glove box.
| | | | | Joined: Jan 2019 Posts: 14 'Bolter | | 'Bolter Joined: Jan 2019 Posts: 14 | JW,
Not answering your question directly at first, but I love the heated seats and steering wheel in my modern vehicle.
An almost direct answer to your question, I have installed seat heaters that I'm sure are virtually identical to what you're speaking of in a 99 Taurus, 97 Saturn and an older Ford camper. All worked well and installed as you would expect. If you're already doing the upholstery, adding the heaters to the seat is almost effortless.
Art
| | | | | Joined: May 2015 Posts: 11,031 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,031 | I think your relay failure crisis has muddied your perceptions.
These things are completely adjustable. On the low setting, I can’t even tell the heat is on! Could be, but on the wife's Escape, even on the lowest setting I turn it off. Maybe my privates are just too sensitive.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Nov 2020 Posts: 71 'Bolter | | 'Bolter Joined: Nov 2020 Posts: 71 | I have used the jungle site seat heater kits in several vehicles. They work as expected for something from Amazon. I have a kit waiting to be installed in my TMI bucket seat that are in my 51. | | |
