0 members (), 78 guests, and 12 robots.
Topics128,021
Posts1,055,355
Members48,420
#1491920 03/13/2023 6:39 PM
Recently purchased a 1948 3800 and I believe it has a fire extinguisher mounted in the cab? The only issue is that when I opened it, the clearish liquid inside smelled of brake cleaner, gasoline, or something highly flammable.....Please dont mind the holes in the floor lol
Older fire extinguishers used carbon tetrachloride. Highly hazardous stuff. Link Please don't be sniffing it. big_eek
Yep, that's a brass canister extinguisher, filled with Carbon Tet. It'd carcinogenic, but it also makes some if the best thread tapping lubricant that's ever been invented. Drain the canister and store the liquid in a tightly capped mason jar. Just have plenty of ventilation if you use it as a thread tapping lube.
CBall #1491969 03/13/2023 10:43 PM
Moderator
Moderator
2 Offline
Jerry is right about it being the best tapping fluid for steel and stainless steel!
But not on aluminum, it will gum up the tap and you will break the tap.
Don't ask me how I know.
Don
"The Flag Pole"
1946 2-Ton grain truck
1946 3/4-ton pickup,
1953 1-ton pickup
1957 1-ton flatbed dually,
1954 Pontiac Straight Eight
CBall #1491980 03/13/2023 11:14 PM
Nice! Ok will do about putting it in an air tight container. I will also start looking around for a new label for it and polish it up!
What make is it?
I have the same type , no label . Most are from 40' & 50's.
Mine polished up pretty good.
1950 Chevy 3100
CBall #1492070 03/14/2023 12:16 PM
Carbon Tet was commonly used in the dry cleaning industry pre 1960ish. Scientists noticed a correlation between dry cleaners and higher death rates and began a study. The stuff was outlawed soon afterwards. There was a story floating around at the time of a man who picked up his suit from the cleaners and put it on the next day for work. Walked in the door of his business and dropped dead. Ambulance personnel noticed a strong odor of Carbon Tet on the body. As I said it was a story at the time, who knows if true or not.
CBall #1492071 03/14/2023 12:26 PM
This Pyrene fire extinguisher is in my old road department truck.
CBall #1492078 03/14/2023 12:49 PM
Can those old extinguishers be refilled with modern stuff to be re-used?
1950 Chevrolet 3100 (Ol' Roy)
I don't know of a fire suppression liquid other than carbon tet that's stable enough to stay liquid without being pressurized in a sealed container. Halon comes to mind, but I believe it had to be contained in a pressure vessel. It's also almost impossible to find due to some sort of so-called health hazards .
Probably will just empty it out and clean it up and either leave it empty or find something else to put in to keep it operational but not be used as a fire extinguisher.....maybe Bourbon? LOL
But officer, I’m not drinking! it’s a fire extinguisher
Officer: OK, prove it. Put out that fire. wink
Moderated by  klhansen, Rusty Rod
