3 members (WICruiser, Phak1, 1 invisible), 40 guests, and 1 robot.
Topics128,089
Posts1,056,009
Members48,430
I am going to do some fab work on one of my Art Deco COEs someday and I'm wondering if anyone knows the first GOOD year powersteering was available. I want to get a box that is simular if possible. Even another maker if somebody thinks it may work.
When I yield to Him, it's amazing how peaceful and enjoyable life is meant to be.
1947 Chevy COE
None had a p/s box. Later years used an assist cylinder in the linkage or just off box pitman arm. These require many pressure sensing valves, lots of hoses and isn't feasable to hack an important system from one truck to another. If you put in new kingpins, tie-rods if you can find and new steering link you will have nice easy steering most of time. Other choice, I don't believe in is using a Motorhome or P-chassis truck chassis with all new systems on it, just use your body on newer frame. My .02 worth!
G.L. Grumpy's
Old Iron Ranch
Huntington, IN 46750
MM R tractor, Speedex
and Power King tractors
I'm not a big believer in using newer frame stuff either. I want to find some power box from something that I can adapt to fit into an old Art Deco COE. I think it will have to be a bigger truck than pickup although the original boxes are quite small.
1947 Chevy COE
