2 members (Johnnydog, 78buckshot), 95 guests, and 2 robots.
Topics128,060
Posts1,055,832
#149099 11/05/2006 2:36 AM
I am working on a '46 2-Ton dump truck. Something didn't look right, this truck was very much rebuilt/modified.
A think someone removed the reinforcement plates from both sides of the frame, also the runningboards and brackets. They removed the rear springs and axle, which left the outside of the original frame clean and bare.
It seems they had a donor truck, that was cut off under the cab floor, it may have been complete with the dump bed. This rear frame assembly was cleaned out by removing all crossmembers and hardware,from the inside, leaving the rear axle assembly and springs installed.
Then the donor frame was slipped over the original '46 frame, telescoped, to the correct wheelbase, the outside plates were re-installed, and now is a 3-thickness frame!
Note, the donor frame top flange was cut off behind the '46 cab, the bottom flange and side end just behind the front spring, matching the frame outside plate. A very professional looking job!
"Nothing is ever as simple as just turning wrenches!"
#149100 11/05/2006 6:01 AM
Anonymous
Unregistered
Anonymous
Unregistered
cool,got any pics of the truck?
#149101 11/05/2006 10:41 PM
I need to wash it some before pix, that will take a while. Watch this space for pix.
#149102 11/06/2006 6:08 PM
Junior Member
Junior Member
I'd sure like to see it. Sounds like it was done right and that's always good...
#149103 11/13/2006 2:11 AM
The donor frame is larger than the original, you can see it sticking out in several places. The top flange was cut off under the cab, and forward. The web is in there, but doesn't show up very well.
http://s144.photobucket.com/albums/r165/Ccer148/
#149104 11/13/2006 2:45 AM
Junior Member
Junior Member
Looks plenty beefy. That is one great looking truck, too...Thanks for the pics....
#149105 11/13/2006 3:33 AM
My '46 Chevy Holmes Wrecker was done this same way. I don't think these jobs were done by the purchasers. May have been ordered this way.
Spanky Hardy
More pictures on Photobucket
1950 GMC 250 1-Ton
#149106 11/13/2006 4:14 AM
I know that sometimes on big dump trucks and cement trucks they have a double frame from the factory.
Dump truck and wrecker haul heavy loads, I bet they came from the factory this way, maybe as a special order like Spanky says.
Here is a link to some stuff about my brothers and I
http://bus-plunge.blogspot.com/search?q=hemmings
#149107 11/13/2006 5:02 AM
I doubt that THIS was a factory job, the cuts of the donor frame are not square, not even length, (one side of the donor frame was cut short enough to clear the cab, The other side was longer, and rubbed the bottom off the cab.) Maybe a copy of a factory job?
#149108 11/13/2006 7:04 AM
prolly someones way to get a complete dump setup on a truck that worked but didn't have a dump
#149109 11/13/2006 10:23 PM
My 38 has nearly the same style of re-enforcement,it also looks to be the same dump body on it too.
#149110 11/19/2006 2:53 AM
These trucks weren't available with reinforced frames from the factory. When using dump bodies or other heavy bodies, the body builder would fabricate a 1/4" plate that went from under the cab to just in front of the rear spring hangers. The plates were call "fishplates". A truck body exerts the most stress to the frame at the extreme front of the body where the body stringers end, while a hoist puts its stress at its mountings. It's usually not as hard on the truck because the truck is standing still when the hoist is used, but I've seen a lot of frames collapse and bend at the front of the hoist mounts. A properly selected hoist will take into account the truck frame strength.
Probably more than you need to know, but it explains why fishplating was done
51 Chevrolet Canopy Express
02 K25 Duramax Crew Cab
