1 members (Hotrod Lincoln), 72 guests, and 0 robots.
Topics128,049
Posts1,055,680
#149084 11/03/2006 1:51 PM
Junior Member
Junior Member
Can anyone help with a couple of nagging problems I'm having with my '68 c-50.
1. The brakes build pressure until they are locking up (and sometimes release pressure and everything is fine and sometimes I have to pull the master cylinder off to release the pressure). I've replaced the booster, master cylinder, brake lines and fluid.
2. The previous owner cobbled a Chrysler Lebaron air cleaner on. I've looked unsuccessfully on ebay and local junk yards for the correct one. What are my options here? Can I find an aftermarket at say NAPA? Will I get more power by getting a larger one?
Thanks.
#149085 11/03/2006 1:56 PM
Check the master cylinder pushrod(between pedal & master cyl) --if there is no slack & the pedal keeps slight pressure on the master, pressure will build up in the system. Brian
My \'64\'s in the Gallery
Pictures in my Photobucket
1964 C10 Custom Cab 350/700R4
1964 Suburban 350/700R4
1979 Ford F350 4x4 400/c6
#149086 11/03/2006 1:59 PM
Junior Member
Junior Member
Thanks, I'll check it again but why would the pressure only build sometimes and sometimes be no problem?
#149087 11/03/2006 4:59 PM
does the brake pedal seem to feel normal, I mean like not hanging up..............?
Redryder pix
My Hotrod
#149088 11/07/2006 3:11 AM
Junior Member
Junior Member
Everything feels great until slowly it seems like the engine is working a little harder and when I come to a stop I notice I'm not rolling in neutral.
#149089 11/07/2006 3:45 AM
3B Offline
Hy tony b, you say you remove the master cylinder to get the pressure to go away, do you physically remove the master or just crack the lines? As others have said an increase in pressure can be caused when the master cylinder cannot return to its fully released position, either by mechanical linkage binding or improper adjustment of the pushrod. I assume that a truck of this size has power brakes, the only other thing I can think of is a sticking atmosphere valve in the power brake booster, not knowing what kind of booster you have the only suggestion I can make is to replace the booster,hope that helps.
#149090 11/10/2006 1:31 AM
Junior Member
Junior Member
The booster is "new" and yes I actually just crack the lines.
