5 members (latroca52, Woogeroo, Mike Burns, Rusted Nut, TS3600), 68 guests, and 3 robots.
Topics128,188
Posts1,057,334
Members48,469
moving some fuel lines around took off the quick connect female side of regulator and moved my lines put it back together and it started leaking.
Pulled it out. looking around and found 5 orings and or parts in there.
How many are supposed to be inside that female end?
Most all o-ring applications are singular, not plural.
One of your o-rings is broken.
I concur on both those points. Just never looked in or had this issue before so it was a little confused when 5 came out two were broken. 3 were not.
there were two more in pieces. not sure it that occurred during disconnection and reconnection or manufacturing issue I never noticed.
More details.
Universal LS Swap Fuel Pressure Regulator Filter Kit - Compatible with C5 Corvette
GF822, 10299146, 19239926, 33737
Its running a 6.0 LS engine. In the 56, 3200
We had used these before. I was replacing it because of pressure increases as well as re-routing some fuel lines. The pressure increases over time is a known issue with these if running larger pumps which I am not but its location had a high heat area causing it to start to fail is my guess.
The new one had a 6an to quick connect adapter in it. When I took it out a pile of o'rings came out with it.
I got another one late yesterday from the local parts store.
Inside that vendor model it has two o'rings sandwiched between two plastic pieces held in place by the internal quick connect release. it works much better. and holds under pressure. it does leak if I move the fitting around while under pressure. I am confident replacing the quick connect fitting will solve that issue. Some are known to not have the correct radius they should.
The first new one did not have the two plastic pieces when it came apart.
The original one I took off the fitting is seized in and will not even spin. Plan on taking that one apart later to see what it has inside.
