3 members (Brian Moore, klhansen, wilbur53), 100 guests, and 2 robots.
Topics128,126
Posts1,056,356
Members48,441
I took the wiper motor out of my 54 3100 and lubed it up good trying to get them to work again. Motor worked real good sitting on the fender.. put it back together and it still cycled to the windshield edge and quit.
Took my daily 15/20 mile ride today when out of the blue they started working like a goose getting airborne at the pond... FopFopFopFopFopFop! Weren't working as they should but working non the less. Back to the shop.
Come to find out that the trans arm was hanging up on the repop defroster vent seam. A sharp wood chisel carved out the offending plastic and now they work like new. Hallelujah! Saved me a bunch of bucks replacing the motor!
I'm stoked!
Jethro.
~~ Jethro
1954 3100
Back to Life
In the Dity Gallery
1951 3100 (gone) / 1956 4400 (still in the neighborhood) / 1957 6400 with dump body (retired) / 1959 3100 panel (in the woods junked) / 1978 Custom Deluxe K10 / 1993 S-10 4.3 / 2004 Chevy Crew Cab / 1945 John Deere H / 1952 John Deere B / 1966 John Deere 2510 / 1967 John Deere 1020
Jethro,
That's good info! yahoo
Got any pictures to share on the repop defroster vent seam "modification" so others may know what to look for if they have a similar problem???
Thanks for sharing. thumbs_up
~ Dan
1951 Chevy 3 window 3100
Congrats thumbs_up Vacuum wipers look great flopping back and forth. Intermittent pauses, speed ups and slow downs...You can tell they aren't electric and really adds to the charm of an antique vehicle, IMO. Until they're all you have in a rainstorm. grin They work even better when paired with Rain-X.
Matthew 6:33
1952 Chevy 1/2-ton 3100
Late '55 235/SM420/torque tube 3.55
Dalton Highway survivor (using original 216)
www.truckwithaheart.com
Naaa... I looked under the dash as I operated the switch and saw the defroster hose move when the arm stopped. Took the glove box out for access and saw where the arm had been contacting the duct... right on the seam. Took the arm loose from the motor, operated it by hand and saw where I needed to trim. Used a sharp wood chisel and removed a big enough V from the seam to clear the arm. Bingo.
The repop is 2 pieces sealed together leaving a 3/16 or so seam. The original was most likely metal with no seam. The repop fit the truck perfectly with pop rivets but that dastardly seam was in the way.
Soooo... if someone has repop ducts and the wipers stop at full cycle, look for interference with the trans arm.
~~ Jethro
1954 3100
Back to Life
In the Dity Gallery
Thanks for the corrective action description Jethro - LOL! wink
I wouldn't want to get up under there for pictures either - haha. nono
I was not familiar with the repop duct construction, so thanks for explaining the situation.
Dan wave
~ Dan
Jethro Good information saw 2 or 3 wiper motors in my pile may try to use one on your good fortune.
