Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
3 members (KEVINSKI, 68ironhead, 1 invisible), 103 guests, and 4 robots.
Topics128,274
Posts1,058,436
Members48,490
#1489903 02/28/2023 3:10 AM
Replacing both tie rods ends on my 47 3100. I'm 75% certain I did not reverse the rod while unscrewing the ends, but I want to get it correct.
So, which side is supposed to be left-hand threaded, and vice versa?
Thanks in advance
1947 3100 Advanced Design
Never, never, never, never give up. - Churchill
RH on the left (driver's) side.
Doesn't really make any difference with new-style ends once you set the toe-in and clamp it down. With old-style adjustable ends you need to keep the same end on the same ball at re-assembly. And count the threads.
~~ Jethro
1954 3100
Back to Life
In the Dity Gallery
1951 3100 (gone) / 1956 4400 (still in the neighborhood) / 1957 6400 with dump body (retired) / 1959 3100 panel (in the woods junked) / 1978 Custom Deluxe K10 / 1993 S-10 4.3 / 2004 Chevy Crew Cab / 1945 John Deere H / 1952 John Deere B / 1966 John Deere 2510 / 1967 John Deere 1020
