1 members (Hotrod Lincoln), 41 guests, and 0 robots.
Topics128,035
Posts1,055,560
#1489123 02/22/2023 7:09 PM
I looked at the reference page, but my code doesn't seem to match any of them. Is this the wrong serial number that I'm looking at?
When taking pics of stamped or cast numbers, lighting from the side (with a flashlight) sure helps make them clearer. Just a tip. They need to be clean as well as buoymaker pointed out.
That's great, thanks. Sorry these were the only photos I had. So how would I identify its displacement? Its an l6
You would start to ID the displacement by getting better pictures of the casting numbers. There are some additional clues based on pushrod cover height and such, but the casting numbers are the first step.
Tak some pictures all the way around the next time you are with the engine and we can help out more.
From the Rocky Mountains?
Check in with the RM Bolters!
HiPo Forum Moderator
1958 Task Force Truck
Follow in the DITY Gallery
1959 3200 Task Force
The Ballad of Enkidu
Here is a very good link with lots of pictures to help you find the casting numbers, cast date codes, and serial numbers on your I6.
http://1954advance-design.com/Web%20images/casting-code-photos/low-press-codes-ser-nums.html
Once you have that info you can use other sources to check to confirm what that info relates to.
Post more pictures and we can try and help more.
~ Dan
1951 Chevy 3 window 3100
Crusing in the Passing Lane
Stamped numbers and letters on a machined surface behind the distr. will tell a lot.
Ed
Those cast numbers look like "CON4" for the conveyor it was cast on in the foundry (this number doesn't mean anything to us now) and the date code "G247" (wild guess at your code).
As others have said you need to look at the stamped numbers located on the flat surface near the distributor. The block casting number (part number from the foundry) will be made up of 7 or more numbers.
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
