0 members (),
116
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,080 Posts1,055,953 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2022 Posts: 90 'Bolter | | 'Bolter Joined: Jul 2022 Posts: 90 | I got a set of 3/4 ton axles for my 63 k10 daily driver. I have an sm420 trans, power brakes and steering. Since they have 4.56 gears I want taller tires, probably around 35's. I have seen some 9.00/16 tires online but am not sure how bias ply would handle highways and towing. Anyone got suggestions on what to get?
59 chevy Spartan 100, former firetruck 348ci with spicer 5 speed and electric rear
| | | | | Joined: Nov 2021 Posts: 1,258 'Bolter | | 'Bolter Joined: Nov 2021 Posts: 1,258 | Bias ply will skate around at higher speeds. Just have to get used to it. | | | | | Joined: May 2007 Posts: 1,718 Moderator: 60-66 Trucks; North Eastern Bolters | | Moderator: 60-66 Trucks; North Eastern Bolters Joined: May 2007 Posts: 1,718 | I agree. As a daily driver I would think modern tires are safest way to go. Not sure if you have stock suspension and brakes, but I think that would also drive part of the decision. I wear 215/85/16 on 2 trucks and drive them with that in mind. Where in NH? Mark (Ferris) and I need to gather. My K10 might be of interest. | | | | | Joined: Jan 2019 Posts: 2,242 Herder of Cats, Goats, and Sheep (moderator) | | Herder of Cats, Goats, and Sheep (moderator) Joined: Jan 2019 Posts: 2,242 | What size/kind of wheels do you have? That will set some limits on your tire options. | | | | | Joined: Jul 2022 Posts: 90 'Bolter | | 'Bolter Joined: Jul 2022 Posts: 90 | Thats kinda what i was thinking Hambone. It is my year round daily so i want it to drive decent. I do have stock suspension and brakes but am planning on switching some 3/4 ton axles in from another 63. I currently have 33x12.5 on 15x10 rims. Obviously I will have to switch to 8 lug rims if I switch axles. The stock rims that are on them are fine so those are likely what I would use. Im near Keene Hambone, let me know when you are gonna party!
| | | | | Joined: May 2007 Posts: 1,718 Moderator: 60-66 Trucks; North Eastern Bolters | | Moderator: 60-66 Trucks; North Eastern Bolters Joined: May 2007 Posts: 1,718 | I make the trip to Keene and Alstead with some frequency. I will check in. | | |
