3 members (Gdads51, JoergK., 1 invisible), 91 guests, and 3 robots.
Topics128,181
Posts1,057,150
Members48,464
#1488658 02/20/2023 12:16 AM
I recently rebuilt the entire brake system on my ‘46. New master cylinder, all new wheel cylinders, new brake shoes, and all new brake lines and hoses. Bought all the parts from one of the major vendors.
About 90 days out, my new master cylinder failed. The vendor was very good about it and provided a replacement. Now, about 3 months later, my right rear wheel cylinder is leaking!! UGH!!
Is this common? Are the new replacement brake parts that inferior….or have I just had bad luck?
Care taker of a 1946 1/2 ton. Pretty much period correct original. Danny T, from B’ham, Al
O Online: Content
I can't say anything specific about brake parts (yet) but virtually everything you buy today is made by Chinese slaves with virtually no quality control.
They make it so cheaply that the makers don't care how many free replacements they have to give away. It doesn't cost them anything.
Fuel pumps are crap for just about every vehicle I've bought one for in the last dozen years or so. Rubber parts are junk and disintegrate if you look at them sideways.
After two faulty fuel pumps for the AD last year - one straight out of the box, I had the original pump rebuilt. Works perfectly
I saved the master cylinder for the AD because I suspect the one I just installed will fail in a year or so. I figure I'll rebuild the old one or have it done. You could trell by looking at the new one that it was a POS. Rough flash on the casting, etc.
1950 Chevrolet 3100 (Ol' Roy)
It's a lot more likely you'll have good luck on brake parts by having the original stuff rebuilt, even if it involves getting the castings sleeved to correct pitting. I'm seriously considering tooling up to rework brake cylinders by installing stainless steel sleeves- - - -Fabricating holding fixtures for a lathe or a mill isn't terribly difficult, and once the fixture is made, sleeving dozens or even hundreds of cylinders becomes a pretty routine operation. It looks like there would be enough demand for the service to make it worthwhile train someone to keep the machinery humming!
Jerry, I've known of/used a local company for the last 20 years. They have never slowed down.
