| | | Forums66 Topics128,042 Posts1,055,501 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2022 Posts: 162 'Bolter | | 'Bolter Joined: Feb 2022 Posts: 162 | Where is a good source for a flywheel cover for 51, 216 , truck. Thank you
1953 with a 216
| | | | | Joined: Dec 2018 Posts: 2,450 'Bolter | | 'Bolter Joined: Dec 2018 Posts: 2,450 | Luray Put an add in parts wanted here on stovebolt,should be some available. Iv'e had grit fly up into the clutch with that not on there. | | | | | Joined: Oct 2021 Posts: 6,715 'Bolter | | 'Bolter Joined: Oct 2021 Posts: 6,715 | On the plus side, leaving it off keeps all the leaking oil from sitting in there and getting on the clutch.
1950 Chevrolet 3100 (Ol' Roy)
| | | | | Joined: Dec 2018 Posts: 2,450 'Bolter | | 'Bolter Joined: Dec 2018 Posts: 2,450 | Otto I just hate to see oil hanging there in that weep hole ,I think PCV helps the rope to hold oil in but it's a delicate balance to keep a slight inward flow on the seal but avoid a vacuum on the crankcase. | | | | | Joined: Jan 2000 Posts: 734 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 734 | Had a really bad main seal leak and no flywheel cover at the time. After a few miles the back bumper, diff, axle, lower tailgate sill, even the taillights had an oily film on them. So I put the cover back on and suddenly, no more oily spray greasing everything up. Just more localized and heavier dripping out the hole, the mess stayed on centerline maybe on the trans and that was that.
Strangely enough my 216 has always had a rear main leak but it's never gotten on the clutch at all.
Matthew 6:33 1952 Chevy 1/2-ton 3100 Late '55 235/SM420/torque tube 3.55 Dalton Highway survivor (using original 216) www.truckwithaheart.com | | |
