5 members (Jon G, Otto Skorzeny, Hanks custodian, dt235sd, 3800GUY), 166 guests, and 1 robot.
Topics128,105
Posts1,056,205
Members48,436
Is there a template available to locate hole location for passenger side mirror
O Online: Content
Deja Vu?
Wasn't this question already answered?
Locator holes are on the backside accessible from inside the cab.
1950 Chevrolet 3100 (Ol' Roy)
Use an automatic set punch from under the dash. There is a backing plate there with holes in it for the mirror arm.
Push the punch as many times as required to make a dimple in the paint an the outside where the mirror bracket goes.
I believe you can get behind it with a drill and a pilot bit. With the glove box out of the way. At least, that's what I remember doing.
AD Addict & Tinkerer
Here is a picture of the inner brace for the mirror. I can’t guarantee that the bolts you see are in the correct position as it’s not my picture, but you’ll get the idea of how it’s done.
Phil
Project Journals
Stovebolt Gallery Forum
Sorry
Didn’t remember I posted in two threads
There is a NOS right hand mirror installation kit on eBay---not mine---auction number 225341066242. In the listing is a photo of the template used for drilling the holes. It will take some figuring to see if it will give you the information you're looking for.
That kit looks like a mirror bracket for west coast style mirrors. Backing plates and small angle brackets to bolt the mirror arms to. Checking the parts manual for that PN says it's for a large extendable mirror that would be used on a big bolt.
Jack, It's OK. Sometimes I forget my memory pill too. wink
Thanks all
Mirror mounted
If there’s no picture, it didn’t happen. grin
O Online: Content
Hey, that's my line!
:nopics:
Glad you were able to get it done.
From the Rocky Mountains?
Check in with the RM Bolters!
HiPo Forum Moderator
1958 Task Force Truck
Follow in the DITY Gallery
1959 3200 Task Force
The Ballad of Enkidu
