| | | Forums66 Topics128,105 Posts1,056,208 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2022 Posts: 7 'Bolter | | 'Bolter Joined: May 2022 Posts: 7 | one of my winter projects is to get pinion seal on rear end fixed. tried last summer, pulled it apart replaced with identical seal from FLAPS, reused the felt seal as it seemed in good shape. took it for a ride and still had a leak when it got warm. questioning if it was the wrong seal all along? Title for truck says its a 1948 3100. But, serial #'s on engine and tranny both say 1952. 8 bolt rims all around. I can only assume someone took a 1948 body/title and put it on a 1952 3600 chassis. hoping someone can identify this rear end to confirm and then attempt to find correct seal. Raised numbers on differential carrier: 3682126 stamped letters on top of "pumpkin" are very hard to read but I believe 16716? One piece of info I dont have on hand is weight of gear oil I refilled with. Could simply switching to a heavier weight oil remedy this issue? It only leaks when hot leaving a rooter tail of oil spun up onto underside of bed and then a small puddle of garage floor.
1948 3100 according to title. 1952 3600 under the body. 216 ci 6volt
| | | | | Joined: Aug 2018 Posts: 1,004 'Bolter | | 'Bolter Joined: Aug 2018 Posts: 1,004 | Only leaks when hot could mean the vent is plugged and the oil is being pushed out Check the vent and make sure it open and clean -s | | | | | Joined: Sep 2013 Posts: 1,362 'Bolter | | 'Bolter Joined: Sep 2013 Posts: 1,362 | What 2Many said plus a common repair is to put a Speedy Sleeve over the seal worn area of the pinion. Worked for me.
Good Luck
RonR
RonR
1951 3600 with Clark flatbed, T5, 4.10 rear 1970 340 Duster 1990 5.0 V8 Miata (1990 Mustang Gt Drivetrain) 1964 CJ5
| | | | | Joined: May 2015 Posts: 11,067 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,067 | Sounds like you have a later than '52 rear axle if it has an open driveline. I believe a '52 3/4 ton still had an enclosed (torque tube) propshaft setup from the factory. Like was said above a speedy sleeve on the pinion yoke should fix you up. You may have to pull the yoke and measure the diameter to get the right speedy sleeve. Also, when reassembling, a bit of sealer behind the nut helps to prevent oil from seeping thru the splines.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | I believe the 3/4 & 1 ton had torque tube off the transmission & open drive shaft from the carrier brg. on back. If the pinion brg has play in it the seal will not hold.
George They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: May 2015 Posts: 11,067 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,067 | I believe the 3/4 & 1 ton had torque tube off the transmission & open drive shaft from the carrier brg. on back. If the pinion brg has play in it the seal will not hold.
George You are correct, George. I just checked the service manual. My dad had a 51 GMC 3/4 ton as his shop truck and I remember it needing the rear end rebuilt, I vaguely recall the guy at the repair shop (fondly known as "Greasy Bob"  ) using dad's pipe dope to check the gear pattern and turning the driveshaft at the end of the torque tube. Maybe GMC 3/4 ton's use the torque tube rear axle.  I'm sure somebody with a GMC here at Stovebolt could confirm or deny that.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Jan 2022 Posts: 2,455 'Bolter | | 'Bolter Joined: Jan 2022 Posts: 2,455 | My '52 GMC 152 (3/4 ton - they only made them in one wheelbase) has an enclosed driveshaft coming out of the transmission that joins to an open driveshaft at a hanger near the rear of the cab down to the rear end.
'57 GMC 102, Original 347 V8, HydraMatic, 3.08 rear gear, added A/C, disk front brakes, HEI, AFB carb, '98 Honda Black Currant paint. T-boned and totaled 10/12 '52 GMC 152 Stake Bed, Original 228, SM420, added A/C, HEI, disk front brakes, '67 Chev 3.55 rear gear. Gets used as a real truck.
| | | | | Joined: Aug 2018 Posts: 1,004 'Bolter | | 'Bolter Joined: Aug 2018 Posts: 1,004 | All of my 1 tons are a universal joint behind the transmission No part of the drive shaft is enclosed The drive shaft is two parts But maybe that’s not how the USA made them -s | | | | | Joined: May 2015 Posts: 11,067 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,067 | In my defense, that memory is back in the fog of 60 years ago.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Jul 2014 Posts: 892 'Bolter | | 'Bolter Joined: Jul 2014 Posts: 892 | The U-joint yoke often has a groove worn from the seal and a speedy sleeve will fix that BUT they also suffer worn splines from mis-matched U-joint angles or rough shifting or washboard roads. Then they vibrate and will not seal. Make sure you tighten the pinion nut tight enough to hold the splines from moving if they are worn. I don't know if yokes are available to fit the HO52/72 axles. Why GM didn't just run the open drive shaft all the way to the transmission on the 3/4 tons is a mystery to me but all I've seen are closed from trans to carrier bearing, then open. One-tons and up are all open DS trans to pinion. 1951 3800 1-ton"Earning its keep from the get-go"In the DITY Gallery1962 261 (w/cam, Fenton headers, 2 carbs, MSD ign.), SM420 & Brown-Lipe 6231A 3spd aux. trans, stock axles & brakes. Owned since 1971. | | |
