0 members (), 61 guests, and 1 robot.
Topics128,049
Posts1,055,743
#1487711 02/14/2023 4:42 AM
Any clues as to whether this one is full pressure or splash?
full pressure
What indicators tell you that?
From the Rocky Mountains?
Check in with the RM Bolters!
HiPo Forum Moderator
1958 Task Force Truck
Follow in the DITY Gallery
1959 3200 Task Force
The Ballad of Enkidu
This full pressure engine does not have an oil distributor cover on the side that a low pressure dipper engine would have.
See picture of three screw oil distributor below.
My Blog
AD Addict & Tinkerer
Wouldn’t the short push rod cover also tell you that?
Edit: just looked it upon Dave’s site and the answer is no. Here is a [LINK].
Phil
Project Journals
Stovebolt Gallery Forum
Thanks!
I have always heard there is some debate over whether or not full pressure 235’s came from the factory in 53 1/2T trucks built in Canada. This was the factory engine in my truck and it was stuck solid when I bought it in 2006 and I have left it untouched since I pulled it and put it on a stand after filling the cylinders with marvel mystery oil. Last night I pulled the plugs and it turns like it should, a candidate for rebuild for sure!!
Thanks once again
Paul
I've looked at lots of AD 1/2 tons in Alberta in the 20+ years since I dragged mine out of the bush...every 1953 model I have seen had a 60 lb oil pressure gauge vs 30lb for earlier ones. My 1952 model had a short side cover 216...most US information indicates a short side cover as a 235.
You Tube
2 Offline
Canadian block casting 3695408 and 3835814
Are both short side cover 216 engines for 51-52 years respectively.
-s
So much minutia!!
I have 2 3835814 engines, one I know for sure is out of a 52 1T and runs like a top, the other is in a 1/2T frame but locked up solid. I guess I had always assumed they were 235’s!!
