10 members (Hotrod Lincoln, mason86, ndkid275, Paul Mullen, Hawkman, Ponchogl, wilbur53, Rusty Heaps, 49choptop, 1 invisible),
91
0
Mod | | | Forums66 Topics128,050 Posts1,055,680 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2004 Posts: 29,770 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,770 | Got a complete 235- - - -fan to bell housing- - - - -carb, air cleaner, manifolds and all- - - -for $300.00! A guy at the machine shop I do business with will pick it up for me this weekend. It was in running condition until the current owner pulled the cylinder head to try to put it on a 292. His mistake is my good fortune- - - -he just wants to get his money back. Not sure about the year, but if it happens to have a good 848 head, the rest of the engine is a freebie! Jerry
| | | | | Joined: Jan 2019 Posts: 2,242 Herder of Cats, Goats, and Sheep (moderator) | | Herder of Cats, Goats, and Sheep (moderator) Joined: Jan 2019 Posts: 2,242 | | | | | | Joined: Nov 2021 Posts: 1,258 'Bolter | | 'Bolter Joined: Nov 2021 Posts: 1,258 | Awesome. parting anything out on it? | | | | | Joined: Feb 2004 Posts: 29,770 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,770 | I won't know until I pick it up- - - -I haven't actually seen it yet, but it sounds like it might be a runner "as is" or at least a rebuildable core. I trust the guy who found it sufficiently to "buy a pig in a poke" this time. Jerry
| | | | | Joined: Apr 2009 Posts: 15 'Bolter | | 'Bolter Joined: Apr 2009 Posts: 15 | Have 2 235’s with 848 heads sitting out back, one’s a 1955 and the other a 1962! Good score, I know of a 261 that’s gonna go to scrap if nobody takes it. | | | | | Joined: Feb 2004 Posts: 29,770 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,770 | Even freebie stovebolt engines couldn't lure me back to California! I left in 1980 and vowed never to return. Do they have Fastenal stores out there? They ship palletized freight from store to store with their own trucking company, Blue Lane Freight. Jerry
| | | | | Joined: Apr 2004 Posts: 5,070 Authorized Pest | | Authorized Pest Joined: Apr 2004 Posts: 5,070 | Have 2 235’s with 848 heads sitting out back, one’s a 1955 and the other a 1962! Good score, I know of a 261 that’s gonna go to scrap if nobody takes it. Got a fellow (Lou 37) who may be interested in this. He'll be contacting you soon.
~ Peggy M 1949 Chevrolet 3804"Charlie" - The Stovebolt FlagshipIn the Gallery"We make a living by what we get; we make a life by what we give." -- Winston Churchill | | | | | Joined: Jun 2005 Posts: 56 'Bolter | | 'Bolter Joined: Jun 2005 Posts: 56 | Even freebie stovebolt engines couldn't lure me back to California! I left in 1980 and vowed never to return. Do they have Fastenal stores out there? They ship palletized freight from store to store with their own trucking company, Blue Lane Freight. Jerry I found out when trying to ship an engine via BlueLane that they divide the country into two zones; separated at the Rockies. They will not ship from zone 2 (west) to zone 1.
WW2Chevy 1942 Chevrolet G506 1-1/2 ton 4x4 Army Cargo w/ winch
(Retro-roco)
| | | | | Joined: Feb 2004 Posts: 29,770 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,770 | Thanks for the heads-up! I've got more stovebolt engines stockpiled already than I'll ever be able to build up, anyway! I just hate to see even one go to scrap! Jerry
| | | | | Joined: Feb 2004 Posts: 29,770 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,770 | Update- - - -I picked up the engine today. Unfortunately, it's not a 235. It's a complete 261 in running condition- - - -they drove the truck into the shop before pulling the engine and removing the cylinder head. The head is an original 261 item, not an 848. No problem there- - - -a cylinder head mill can turn it into one with an 848 compression ratio, and it will already have the "steam holes" in it. I didn't see the truck- - -it might have already gone to scrap, which was where the engine was headed before I rescued it. It's got the hydraulic clutch bell housing with the slave cylinder on the passenger's side, flywheel, clutch, and pressure plate, a solenoid-type starter, and for some reason, there's a heavy duty 6 volt generator with the large diameter pulley on it. I haven't checked out the starter yet, but the rest of the engine appears to be from the early 1960's. It's also got a full flow canister type oil filter, complete with all the fittings and flex hoses, and what appears to be a big bore Rochester B carburetor. Water pump, fuel pump, sheet metal, and all the gas and vacuum lines were included in the deal! There's a slight ring ridge in the cylinders, but it seems to be mostly carbon deposits.
Maybe I need to go buy myself a lottery ticket? Jerry
| | | | | Joined: Sep 2011 Posts: 1,453 'Bolter | | 'Bolter Joined: Sep 2011 Posts: 1,453 | You're slipping Jerry, no cast numbers & date codes?!!
BC 1960 Chevy C10 driver 261 T5 4.10 dana 44 power loc 1949 GMC 250 project in waiting 1960 C60 pasture art Retired GM dealer tech. 1980 - 2022 | | | | | Joined: Feb 2004 Posts: 29,770 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,770 | Hidden under a protective layer of grease and dirt- - - -maybe tomorrow when it gets daylight! Jerry
| | | | | Joined: Feb 2019 Posts: 4,473 AD Addict & Tinkerer | | AD Addict & Tinkerer Joined: Feb 2019 Posts: 4,473 | Go buy that lottery ticket! You scored big! Congrats!
Phil Moderator, The Engine Shop, Interiors and Project Journals1952 Chevrolet 3100, Three on the Tree, 4:11 torque tube Updated to: ‘59 235 w/hydraulic lifters, 12v w/alternator, HEI, PCV and Power front Disc BrakesProject JournalsStovebolt Gallery Forum | | | | | Joined: Mar 2007 Posts: 3,379 Crusty Old Sarge | | Crusty Old Sarge Joined: Mar 2007 Posts: 3,379 | I'm waiting to hear how you stroke this 261 out to 401...  Great save.
~ Craig 1958 Viking 4400"The Book of Thor"Read the story in the DITY1960 Chevrolet C10"A Family Heirloom"Follow the story in the DITY Gallery'59 Apache 31, 327 V8 (0.030 over), Muncie M20 4 Speed, GM 10 Bolt Rear... long term project (30 years and counting) If you don't like driving yourTruck, you won't drive yourTruck..| Living life in the SLOW lane | | | | | Joined: Jan 2016 Posts: 1,101 'Bolter | | 'Bolter Joined: Jan 2016 Posts: 1,101 | Based on everyone thinking Jerry made a great find I feel real good about mine. I picked up a 1958 235 complete (carb, air filter, oil cannister, water pump, fan, generator, starter and horns) to the bell housing. It turns over by hand. I haven't set it up and tried to start it yet. The guy I got it from brought it back from out west. I am in Kentucky. It was in a 1 ton and he has a custom frame shop. He is going to put the body on one of his frames to showcase his work. He just wanted it gone. The whole thing, $75. I figured I couldn't go wrong even if the engine is garbage I can salvage parts for my 54 235 is I ever needed to. My first choice will be to get it set up on a stand and see how she runs. Possible future rebuild and complete swap if my engine ever fails. | | | | | Joined: Jan 2014 Posts: 3,677 'Bolter | | 'Bolter Joined: Jan 2014 Posts: 3,677 | Based on everyone thinking Jerry made a great find I feel real good about mine. I picked up a 1958 235 complete (carb, air filter, oil cannister, water pump, fan, generator, starter and horns) to the bell housing. It turns over by hand. I haven't set it up and tried to start it yet. The guy I got it from brought it back from out west. I am in Kentucky. It was in a 1 ton and he has a custom frame shop. He is going to put the body on one of his frames to showcase his work. He just wanted it gone. The whole thing, $75. I figured I couldn't go wrong even if the engine is garbage I can salvage parts for my 54 235 is I ever needed to. My first choice will be to get it set up on a stand and see how she runs. Possible future rebuild and complete swap if my engine ever fails. In my simple brain, unless you can see/hear/smell a 235 run, or have really good documentation to prove a recent rebuild…$50-$150 ought to be about the value. It’s a rebuildable core that could just as easily be cracked or otherwise unusable. There’s no way for the seller or buyer to know. They aren’t nearly as common as a SBC core. But even 60 years removed from their last production, 235’s are far from rare. A 261 core is a rarer bird and thus slightly more valauable. The asking prices for on FB and such are too commonly in the $300-$600 range. Most of those also sit unsold for months at a time. (These ideas are probably not entirely my own. The guy that just scored the cheap 261 might have trained me to think this way)
1951 3100
| | | | | Joined: Jun 2022 Posts: 557 'Bolter | | 'Bolter Joined: Jun 2022 Posts: 557 | Jerry... is that an 850 head?
~~ Jethro 1954 3100Back to LifeIn the Dity Gallery1951 3100 (gone) / 1956 4400 (still in the neighborhood) / 1957 6400 with dump body (retired) / 1959 3100 panel (in the woods junked) / 1978 Custom Deluxe K10 / 1993 S-10 4.3 / 2004 Chevy Crew Cab / 1945 John Deere H / 1952 John Deere B / 1966 John Deere 2510 / 1967 John Deere 1020 | | | | | Joined: Feb 2004 Posts: 29,770 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,770 | Jerry... is that an 850 head? 3836850 casting number J 14 9 date code Looks like a 1959 or 60 engine, but I haven't checked the block casting number or build date yet. I've got another late model 261 stashed away, also with the big oil gallery ports and an 850 head, plus two early 261's with the high mount water pump, and a 261 Canadian Pontiac engine. Jerry
| | | | | Joined: Jan 2000 Posts: 734 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 734 | plus two early 261's with the high mount water pump, and a 261 Canadian Pontiac engine. Jerry Did any 261's come from factory with high mount or did all 261's require an adapter plate? I'll be picking up a 1955 261 next week. It has the high mount water pump but I haven't been able to see if it has an adapter plate.
Matthew 6:33 1952 Chevy 1/2-ton 3100 Late '55 235/SM420/torque tube 3.55 Dalton Highway survivor (using original 216) www.truckwithaheart.com | | | | | Joined: Nov 1995 Posts: 5,716 62401 | | 62401 Joined: Nov 1995 Posts: 5,716 | Skooter -- Yes! The early 261's, made for the '54 and '55 1st series trucks (AD trucks) were the high mount water pumps. As well, any of the crate motors produced after those years and specifically as replacement engines for those trucks will be set up for the high water pump. The casting numbers will be your guide. I have a crate motor 261 in my '49 1-ton. It was out of the '54 mold but built in '59. it required zero modifications to mount in my Advance Design truck. (I used my 216's flywheel and distributor, though, to stay 6 volts).
If you *do* find a later ("crate") engine out of the '54 mold, though ... check the casting numbers and serial number for the actual date of the engine -- at some point (I forget off hand) they changed main bearing styles. Refer to the Tech Tip on rebuilding the 261 for further discussion on this.
~ John A kid raised on Hotwheels, Matchbox and Tonka cannot be reasonably expected to own only one vehicle as an adult. 1949 Chevrolet 3804In the Legacy Gallery | In the Gallery Forum1973 IH 1310 Dump1963 Kaiser M38A12001 International/AmTran RE3000 "Skoolie"2014 Ford E-350 4x4 (Quigley) | | | | | Joined: Mar 2007 Posts: 4,215 Moderator | | Moderator Joined: Mar 2007 Posts: 4,215 | Jerry, are you saying that 261 engines didn't come with 848 heads? I see 261s all the time with them, including my own. They are all Canadian Pontiac engines. | | | | | Joined: Jan 2000 Posts: 734 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 734 | Thanks for the info. Don't have the casting numbers yet but the serial number ends in F55N, with one source indicating this would be from a 6000 series truck.
Matthew 6:33 1952 Chevy 1/2-ton 3100 Late '55 235/SM420/torque tube 3.55 Dalton Highway survivor (using original 216) www.truckwithaheart.com | | | | | Joined: Feb 2004 Posts: 29,770 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,770 | As I understand it, the American truck engines ran an 850 casting number head. Not sure about the Canadian production engine, as they had some differences from the USA truck version. The 850 head will have the extra coolant passages and slightly lower compression than the 848 which was a late mode passenger car head. There can be some intake valve to piston clearance issues with some camshaft/cylinder head combinations, particularly if the head is milled to raise the compression ratio. Most 848 heads should have those "steam holes" drilled to assure proper cooling with the siamesed cylinder wall pairs in the 261 engine. Jerry
| | | | | Joined: Jan 2013 Posts: 2,232 Moderator: Interiors, Texas Bolters, Name that Part | | Moderator: Interiors, Texas Bolters, Name that Part Joined: Jan 2013 Posts: 2,232 | I can’t get over Jerry’s thought process that he needs another project to complete! He has enough to last 3-4 life times! | | | | | Joined: Jun 2022 Posts: 557 'Bolter | | 'Bolter Joined: Jun 2022 Posts: 557 | That's ok... one of these days ol' Jerry will go to Stovebolt Heaven and someone down here will go nuts trying to sort out all the engines he had saved from the junk man! Carry on, Jerry.
~~ Jethro 1954 3100Back to LifeIn the Dity Gallery1951 3100 (gone) / 1956 4400 (still in the neighborhood) / 1957 6400 with dump body (retired) / 1959 3100 panel (in the woods junked) / 1978 Custom Deluxe K10 / 1993 S-10 4.3 / 2004 Chevy Crew Cab / 1945 John Deere H / 1952 John Deere B / 1966 John Deere 2510 / 1967 John Deere 1020 | | | | | Joined: Feb 2004 Posts: 29,770 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,770 | Wellll- - - -my father made it to one month short of his 90th. birthday, and shortly before he passed on he was drilling and tapping his Hoveround for a different set of foot rests- - - - -lying in the floor of the assisted living home with a cordless drill and some tools! The nursing staff was impressed, and so were all of us in the family. Impressed, but not surprised! Jerry
| | | | | Joined: Oct 2021 Posts: 6,742 'Bolter | | 'Bolter Joined: Oct 2021 Posts: 6,742 |
1950 Chevrolet 3100 (Ol' Roy)
| | | | | Joined: Jan 2013 Posts: 2,232 Moderator: Interiors, Texas Bolters, Name that Part | | Moderator: Interiors, Texas Bolters, Name that Part Joined: Jan 2013 Posts: 2,232 | If Jerry had a hoveround, it’ll have a major upgrades so he can drag race in the hallways. I can see it now.
Chris | | |
