1 members (Millenimech), 118 guests, and 2 robots.
Topics128,135
Posts1,056,422
Members48,441
Hello,
I am looking to replace my front and rear leaf springs in my 54 3100 but are not sure if the current ones are stock height. The drop was done before I got it. It has a front drop axel installed and4” or 5” lowering blocks in the rear. Any suggestion on how to determine? I want to keep it how it sits currently but with new leafs and mounting hardware.
Here's a couple pics of new stock front springs on my '52, also shows how much the 216 settles them down after installation. Wouldn't think '54 would look much different. I could be wrong.
Matthew 6:33
1952 Chevy 1/2-ton 3100
Late '55 235/SM420/torque tube 3.55
Dalton Highway survivor (using original 216)
www.truckwithaheart.com
Skooter's pics look just like the new springs I got for my 54 3100 from St. Louis Spring several years ago.
Samantha
1954 Chevy 3100
Picked from the Field
Follow in the DITY
Spec for 1954 ½ ton springs
The last four numbers of the part number should be stamp on the bottom leaf. Front 2793 Rear 3317
Jimmy, do you have a source for those specs? I have been looking for that info for my 58 for a while. Maybe your source has some newer info too?
From the Rocky Mountains?
Check in with the RM Bolters!
HiPo Forum Moderator
1958 Task Force Truck
Follow in the DITY Gallery
1959 3200 Task Force
The Ballad of Enkidu
Are you having issues with the springs that you have now?
Edit: I think you were asking the OP if he had spring issues.
@jimgmc. Thank you for the info. I will look for the numbers
@52Carl I am not having any spring issues now. Was just trying to update item as I go. The shackles need replaced for sure so I thought I would replace the spring before I had an issue with one of them as well.
Thank you everyone for the replies.
55-56 Second Design
57-59
Front
Rear
If this were my truck, I would remove the springs from the truck and remove the bushings from the springs and inspect the spring eyes to make sure that the bushings did not wear all the way through and damaged the spring eyes.
If there in no wear there and the springs are not heavily pitted from rust, I would use what you have.
New springs are generally stiff. They are designed to do the work which these trucks were designed to do. Haul heavy loads. You may not like the ride which new springs may provide. I doubt you are planning on hauling much in your truck, judging from its stance in your pics.
