0 members (), 91 guests, and 1 robot.
Topics128,055
Posts1,055,782
#1486487 02/05/2023 12:43 AM
Guys
Is there a linkage between wiper switch and vacuum wiper unit
If so are they available
How does wiper linkage attach to motor
Many thanks
Yes, it's a short rod with a Z bend on one or both ends. I'd have to dig mine out to look at it to be sure.
That applies to 47-54 trucks. You didn't specify what you're working on. They are available. Link
Title says 49...
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
blush
It’s a 49 panel
AD Addict & Tinkerer
The wiper arms are held in place by a spring assembly. Here is a [LINK] It gets stretched between both posts the arms attach to.
Phil
Project Journals
Stovebolt Gallery Forum
I have had nothing but trouble keeping that switch-to-vacuum motor connecting rod in place using the aftermarket rubber grommets.
I gave up on the rod and the grommets and used a length of TIG feed wire (similar to coat hanger wire).
It's a pretty simple matter of bending the ends all the way around so that the rod ends cannot fall out. Works fine, last long time. If it rattles, I cannot hear it over all of the rest of the rattles. smile
Perfect
That works for me
And I found the rod
Thought I had one
52Carl #1487670 02/13/2023 9:20 PM
I put some heat shrin
I put some heat shrink tubing over the end of mine (and shrunk) - with the speedometer removed I could access it OK. So far, so good haven't lost it since. The grommet still had a tight slip fit, but it would work its way up - tubing seems to have prevented that.
1949 Chevrolet 3/4 Ton - Still Solid. Regular Driver
OT Vehicles:
1925 Hudson Brougham Super Six
1950 Chevrolet Styline (Parts)
1952 Canuck Pontiac Sedan Delivery (Well Underway)
1973 F250 4x4 Highboy
1977 F250 4x4 Lowboy
Great idea
