0 members (), 191 guests, and 2 robots.
Topics128,089
Posts1,056,141
Members48,436
I have a Pertronix 1168LS ignitor but I'm not sure about the correct coil. I have a Pertronix 40,000v 1.5ohm coil but I'm wondering if I should have a 3.0ohm coil. I don't see the ohms stamped on my stock NAPA no resistor required coil. The stock distributor will be used for installing the ignitor. Thank you for answer. 1.5 or 3 ohm coil? Will need thr full 12v .
It is my understanding that one is for 6 volt and one is for 12 volt. I don’t remember which. Good luck with Pertronix.
Thank you. I'll return the 1.5 ohm Pertronix coil. I will install the Pertronix ignitor with my stock 12v NAPA coil.
Riding in the Passing Lane
I would call or e-mail Pertronix & find out for shure which is right. I believe the mismatch of coils & resistors are what causes Pertronix failures. I have installed several & never had a failure.
George
1972 Chevy c10 Cheyenne Super
1958 3100 Fleetside w/235 4spd
Pertronix T. Barnum is alive and well, and these days he's selling ignition systems!
LOL!
I have tried them.
They work great, until they don't. AAA is a must have.
When they do work, they don't work any better than a fresh set of points and a good capacitor.
If my points become not-so-fresh while I am out on the road, I know that all I need to do is clean them up somewhat to get me home.
Bondo Artiste
Bondo Artiste
Pertronix. Best upgrade I’ve ever made to my vintage vehicles. 15k miles and counting trouble free miles.
~ Phillip
Those of us who have had Pertronix failures won’t recommend them to anyone. Those who have had good luck with Pertronix swear by them. All I can say is if you do convert to Pertronix carry in your glovebox a set of points, condenser and rotor along with the hardware and tools to install them. It’s called being prepared.
In addition to carrying a set of points, condenser, hardware, and tools, you will need the original wires and the special insulator where they enter the side of the distributor, as well as a ballast resistor if you are running 12 volts.
The simplest way to deal with the issue is to carry a spare distributor that's already set up with points. There's a hole in the passenger's side of the engine block that's designed to hold it- - - -put the Pertronix distributor in a cardboard box under the seat and it will never cause you any trouble!
Bondo Artiste
Bondo Artiste
How about just carry a spare pertronix in the glovebox?
~ Phillip
