2 members (Gray_Ghost, RoseB),
153
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,089 Posts1,056,141 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2015 Posts: 78 'Bolter | | 'Bolter Joined: Sep 2015 Posts: 78 | I have a Pertronix 1168LS ignitor but I'm not sure about the correct coil. I have a Pertronix 40,000v 1.5ohm coil but I'm wondering if I should have a 3.0ohm coil. I don't see the ohms stamped on my stock NAPA no resistor required coil. The stock distributor will be used for installing the ignitor. Thank you for answer. 1.5 or 3 ohm coil? Will need thr full 12v . | | | | | Joined: Apr 2005 Posts: 7,440 Bolter | | Bolter Joined: Apr 2005 Posts: 7,440 | It is my understanding that one is for 6 volt and one is for 12 volt. I don’t remember which. Good luck with Pertronix.
| | | | | Joined: Sep 2015 Posts: 78 'Bolter | | 'Bolter Joined: Sep 2015 Posts: 78 | Thank you. I'll return the 1.5 ohm Pertronix coil. I will install the Pertronix ignitor with my stock 12v NAPA coil. | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | I would call or e-mail Pertronix & find out for shure which is right. I believe the mismatch of coils & resistors are what causes Pertronix failures. I have installed several & never had a failure.
George They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Jan 2023 Posts: 36 'Bolter | | 'Bolter Joined: Jan 2023 Posts: 36 |
1958 3100 Fleetside w/235 4spd
| | | | | Joined: Feb 2004 Posts: 29,798 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,798 | Pertronix T. Barnum is alive and well, and these days he's selling ignition systems! LOL! Jerry
| | | | | Joined: Mar 2010 Posts: 10,280 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,280 | I have tried them. They work great, until they don't. AAA is a must have. When they do work, they don't work any better than a fresh set of points and a good capacitor. If my points become not-so-fresh while I am out on the road, I know that all I need to do is clean them up somewhat to get me home.
| | | | | Joined: Jun 2001 Posts: 793 Bondo Artiste | | Bondo Artiste Joined: Jun 2001 Posts: 793 | Pertronix. Best upgrade I’ve ever made to my vintage vehicles. 15k miles and counting trouble free miles.
~ Phillip 1949 GMC Suburban - 10 year project 1952 Pontiac Chieftain Convertible straight 8 hydramatic 1945 GMC half ton truck - Driver- Sold 9-15-25 1946 Chevy COE - SOLD 1-5-26 BUH BYE CHEVY! 1959 GMC Half ton long bed NAPCO | | | | | Joined: Apr 2005 Posts: 7,440 Bolter | | Bolter Joined: Apr 2005 Posts: 7,440 | Those of us who have had Pertronix failures won’t recommend them to anyone. Those who have had good luck with Pertronix swear by them. All I can say is if you do convert to Pertronix carry in your glovebox a set of points, condenser and rotor along with the hardware and tools to install them. It’s called being prepared.
| | | | | Joined: Mar 2010 Posts: 10,280 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,280 | In addition to carrying a set of points, condenser, hardware, and tools, you will need the original wires and the special insulator where they enter the side of the distributor, as well as a ballast resistor if you are running 12 volts.
| | | | | Joined: Feb 2004 Posts: 29,798 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,798 | The simplest way to deal with the issue is to carry a spare distributor that's already set up with points. There's a hole in the passenger's side of the engine block that's designed to hold it- - - -put the Pertronix distributor in a cardboard box under the seat and it will never cause you any trouble! Jerry
| | | | | Joined: Jun 2001 Posts: 793 Bondo Artiste | | Bondo Artiste Joined: Jun 2001 Posts: 793 | How about just carry a spare pertronix in the glovebox?
