1 members (Woodcmiami),
86
Mod | | | Forums66 Topics128,100 Posts1,056,513 Members48,448 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2022 Posts: 86 'Bolter | | 'Bolter Joined: Sep 2022 Posts: 86 | Im going to be taking off the front end of my 1953 Chevy Panel Truck soon. Im not taking it off as a clip because i dont have the room to store it inside the garage connected together,but i can store it inside seperately. I will take the hood off first,then take pics. of the wiring locations and paths. I have to replace all the 6 volt wiring to 12 volt at some point because the cloth is broken off and I want to upgrade to 12 volt anyway for brighter lights,add radio and some interior lights in the back,etc. I already removed the front bumper a few months ago. i already purchased a shop manual,Assembly manual and a 6 volt to 12 volt conversion manual. Correct me if im wrong, but next thing after taking pics of the wiring paths and removing the old wiring is to drain the radiator then removing the hood latch/catch assembly ,grill,lower filler panel and core support and outer fenders. After I get everything off the front end ,I will be pulling the 6 cyl. engine and 3 spd. transmission ,get them out of the way so I can start working on replacing the Inner and outer cowl panels,Inner and outer kick panels,floor boards LH & RH and the toe boards and maybe part of the firewall panel ,(depends on how far up the toe boards go. So , what do I start to replace first ??? the kick panels first,then the LH & RH floor boards second ??? and then the toe boards ??? Im planning on buying all the repair panels first and see how they fit and line up ,before cutting out the rot. Any help would be greatly appreciated on this. I also have to replace the panel above the windshield Inside the truck. Thanks, Mark. 1953 Chevrolet 1/2 ton Panel Truck 3100 4800 LB. maximum rating, 85hp at 3300 RPM | | | | | Joined: Sep 2022 Posts: 86 'Bolter | | 'Bolter Joined: Sep 2022 Posts: 86 | Hopefully someone will chime in on this sometime this week ?? Theyre had to be several guys who have had all theserepair panel to replace at sometime. 1953 Chevrolet 1/2 ton Panel Truck 3100 4800 LB. maximum rating, 85hp at 3300 RPM | | | | | Joined: May 2015 Posts: 11,104 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,104 | Mark, You're right, there are several of us who have replace floor and cowl panels on AD trucks, me being one. The pickups and panels are the same from the doors forward, so the same things apply. As far as sequence, if you also need to replace rockers, that might be your first item to get in place. If they're rusted away at the hinge pillar (very common issue), they are critical to maintaining the door opening dimensions. Other than that, I would start with the floor and toe panels, then work my way out. The floor laps over the rockers, then the kick panels lap over that, then the hinge pillar. That joint is going to be one of the last ones that you should weld. In fact, you'll need to fit EVERYTHING in the lower cowl area before welding anything solid. Use sheet metal screws to hold things in place temporarily. Take a look thru my pictures. Specifically around here and working backward in time. You'll want to brace the cab before cutting the rust out to maintain the correct door openings and hinge pillar location. The Factory Assembly manual has cab dimensions that you should check to be sure things are correct before final welding. There are others who have shared their experience over in Paint and Body. Some browsing thru that forum might be helpful to you as well.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Sep 2009 Posts: 5,964 Gearhead, Stovebolt Tech and Parts Tracker, Mod for Swap Meet and GTT | | Gearhead, Stovebolt Tech and Parts Tracker, Mod for Swap Meet and GTT Joined: Sep 2009 Posts: 5,964 | Garageguy6078, Since your '53 Panel truck repairs involve primarily the cab front body sections and floor (from your description), you may want to ask this question in the Paint and Body Shop forumYour questions apply to all such truck cab sections, with little variation until you start moving to the rear beyond the door openings. Here is just one of many conversations about what you are asking about found using the Search the Site link in the left margin of the page: https://www.stovebolt.com/ubbthread...98507/re-cab-rust-repair-what-order.htmlBetween re-asking your question in the Paint and Body Shop forum, and using this tool to further search for previous conversations, I think you will get more response and have a good bit of info to help decide on your plan. Another very necessary and useful resource you should have is a Factory Assembly Manual. The GM approved reprint I have is titled 1947-1954 TRUCK Factory Assembly Manual. This book has detailed truck assembly sheets for most every section of our trucks, along with diagrams that provide specific body measurements as initially designed for assembly specifications at the factor. These reprinted books are available form many sources. Do a web search and you should be able to get one in hand fairly quickly. One other suggestion - take a look at other Project Journals for folks with 1947-55.1 Advance Design trucks. Many of them have probably done what you are looking to start and their information and pictures they have posted will be of help too. Hope this is of some help in moving your project along. Dan  EDIT: Seems Kevin beat me to the posting punch - lol. Hope all we have noted is helpful!
~ Dan 1951 Chevy 3 window 3100Follow this story in the DITY Gallery"My Grandpa Carl's Truck and How it Became Mine"1966 Chevelle (Wife's Hot Rod) | 2013 Chevy Silverado (Current daily driver) US Army MSG Retired (1977-1998) | Com Fac Maint Lead Tech Retired (1998-2021)
| | | | | Joined: May 2015 Posts: 11,104 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,104 | Mark Here's a video that I ran across a while back. www.youtube.com/watch?v=3UhYW3ee-H8 It shows how the parts go together. One thing I noticed about it was that he has minimal bracing on the door opening. There are more out there that you can get ideas from. They may not be doing it right, according to some, but sometimes bad examples can be helpful.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Mar 2007 Posts: 55 'Bolter | | 'Bolter Joined: Mar 2007 Posts: 55 | Hello Guy, Wow, the allure of the panel truck, went down this rabbit hole 15 years ago still trying to find my way out. I think you need to address the floor and toe panel area first. Perhaps you can find a donor panel truck for the floor seat riser area as I believe this area is unique to the panel trucks and nobody makes the repop,(at least at the time I did mine) or maybe fabricate something yourself. | | | | | Joined: Sep 2022 Posts: 86 'Bolter | | 'Bolter Joined: Sep 2022 Posts: 86 | King Kielbasa, thanks for replying, the floor seat riser and what it sits on are ok,its everything in front of it, L&R side floor pans,toeboards L&R side kick panels,L&R inner and outer cowl panels,radiator core support,braces for floor,metal section inside the truck above the windshield. There is no hope of finding a donor panel truck for parts, Im very fortunate to have found this truck. Its really very straight and pretty complete,just missing the starter and air cleaner and glass fuel bowl, and needs alot of repair panels cut out and welded in. Im doing the cutting and welding,just need to know the best way to brace everything and where to start first. Thanks. 1953 Chevrolet 1/2 ton Panel Truck 3100 4800 LB. maximum rating, 85hp at 3300 RPM | | | | | Joined: May 2015 Posts: 11,104 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,104 | Mark, You may not have noticed this in my post above: "The pickups and panels are the same from the doors forward, so the same things apply."
So you don't need a panel truck as a donor. Any pickup cab from 51 or later would work. You could theoretically slice that donor pickup cab and yours in two right in front of the seats and splice the two good parts together. I don't think I'd recommend that option though. It would be difficult to get everything aligned correctly and have a decent seam across the roof.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Sep 2022 Posts: 86 'Bolter | | 'Bolter Joined: Sep 2022 Posts: 86 | Klhansen, Thanks for replying. Yes i did notice that you mentioned about the pickups from the back of the doors up are the same as the panels. Im going to just use the best quality repair panels that i can get to repair my Panel Truck. I cant wait till March because thats when im going to get the repair panels . Im going to start taking off the hood,fenders radiator core support and radiator,inner fenders,wiring ,and then pulling the motor and transmission ,so that I can get to everything without anything being in my way, bagging and tagging as I go along. I will begin doing this next week. I want to have everything ready so that when the repair panels come in I will be ready to tear into it. 1953 Chevrolet 1/2 ton Panel Truck 3100 4800 LB. maximum rating, 85hp at 3300 RPM | | |
