7 members (tclederman, Woodcmiami, Hotrod Lincoln, Otto Skorzeny, 2-Ton, bobfake, 1 invisible), 41 guests, and 1 robot.
Topics128,091
Posts1,056,034
Members48,433
Is there any way I can determine what type of oil to add to my dump bed? OR, will mixing mineral oil and hydraulic fluid be ok so I don't need to worry about it? Truck is a 57 6300 grain truck. Dump has 3 cylinders, one in the front to get the lift started and two longer ones in the rear. It all works fine but it drips a little when parked so I am thinking I will need to add fluid at some point.
Matt
1957 Chevrolet 6503
14' Grain Dump Box
More story in Big Bolts
7
7 Offline
Tractor Supply has hydraulic oil for tractors, I buy it in 5 gallon buckets for the transmission and hydraulics in my 1955 International Harvester. Or you could use snow plow hydraulic oil, Western Plows has it in 1 gallon jugs.
I have bought the universal oil for older tractors I have had. Was just wondering if it mattered if I mixed that with whatever is in the truck now.
Matt
1957 Chevrolet 6503
14' Grain Dump Box
7
7 Offline
I doubt it will harm anything, as long as it doesn't foam when pumping it should be ok. I assume it's a PTO driven pump?
H Online: Content
A lot of the older dump trucks I've serviced used plain old 30 weight non detergent motor oil in the dump system. One of my customers with a leaky cylinder packing bought the stuff a case at a time. His frame and rear axle had no problems at all with getting rusty!
yes, PTO pump.
Matt
1957 Chevrolet 6503
14' Grain Dump Box
mdkelley I just use hydraulic oil like a backhoe uses,get it at the farm store.
sounds good. I read that if I am worried I can drain some oil from the truck, mix the new with the current in a jar and shake it up to see if it blends or gels... if it mixes well there should be no issues. thanks for the replies
Matt
1957 Chevrolet 6503
14' Grain Dump Box
My 57 6400 uses plain 30 wt. Non-detergent is best. Doesn't foam. Be sure to lay a 4x4 post in the hinge crotch if any service is to be done with the lift up. Safetysafetysafety. Should a hose burst that bed can slam down before one can get out of the way.
~~ Jethro
1954 3100
Back to Life
In the Dity Gallery
1951 3100 (gone) / 1956 4400 (still in the neighborhood) / 1957 6400 with dump body (retired) / 1959 3100 panel (in the woods junked) / 1978 Custom Deluxe K10 / 1993 S-10 4.3 / 2004 Chevy Crew Cab / 1945 John Deere H / 1952 John Deere B / 1966 John Deere 2510 / 1967 John Deere 1020
mddkelly In the olden days some lubricants when mixed would basically turn into soap,I don't think you'll hit that now. That was in the forties.
For what its worth, I run plane jane ATF from the farm store for hydos on all the farm trucks and small equipment for year round use. Regular hydro oil doesn't like the cold weather until its warmed itself up, which isn't really possible on a dump bed like it is on tractors/equipment with hydrostatic drives.
1964 Chevrolet C60 Real Farm Truck
in Gallery Forum
7
7 Offline
The snow plow hydraulic oil that Western Plow markets looks and smells like ATF, might have some additives but who knows.
I use AW 32 hydraulic oil in systems with hydraulic rams. Since you probably have no idea what the previous owner used, I would drain the system. It is probably about time for fresh fluid anyway. AW 32 usually costs about $65 for 5 gallons.
I was thinking along the same lines...
Matt
1957 Chevrolet 6503
14' Grain Dump Box
