| | | Forums66 Topics128,114 Posts1,056,287 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2022 Posts: 13 'Bolter | | 'Bolter Joined: Aug 2022 Posts: 13 | Ok, I scraped a bunch of the crud off the case of the Chelsea PTO that is my ‘54 4400. Under the truck I thought it said 211 as the mode number, but there isn’t a model 211 that I can find. It is hard to read due to the stamping being low, but thought I’d see if anyone has any ideas? https://share.icloud.com/photos/023q4t41jsCagTjyftjxV8WdQ
1954 Chevy 4400 2021 Mimaki JFX200-2513EX
| | | | | Joined: May 2015 Posts: 11,069 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,069 | Looks like it might be a 2 H. You can barely see the horizontal bar of an "H" at the bottom of the boss.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Feb 2016 Posts: 1,989 'Bolter | | 'Bolter Joined: Feb 2016 Posts: 1,989 | I would volunteer to run into town and do some research but I don't know how long Chelsea Products Inc. has been gone, I live 8 miles north of Chelsea.
| | | | | Joined: Aug 2022 Posts: 13 'Bolter | | 'Bolter Joined: Aug 2022 Posts: 13 | I started to think that second character might be a 4. All their model numbers see to be 3 numeric digits.
| | | | | Joined: May 2015 Posts: 11,069 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,069 | Chelsea got absorbed into Parker in 2001. They are still making Chelsea PTOs. You might try contacting them for info. Link
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Dec 2018 Posts: 2,450 'Bolter | | 'Bolter Joined: Dec 2018 Posts: 2,450 | birchandboulder That 2 H almost rings a bell ,fought Chelsea's and others but been 50 years,think klhansen is right. | | |
