2 members (Peggy M, panic),
89
Mod | | | Forums66 Topics128,030 Posts1,055,428 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#14847 08/12/2002 7:16 PM | Joined: Jul 2002 Posts: 18 Junior Member | | Junior Member Joined: Jul 2002 Posts: 18 | a guy wanting to sell me a 1965 230 engine says i can use the transmission, etc in my 49 3600. i can't find any articles saying this is true, 235's up to 1962 seem to me the correct swap
" the first rule of the intelligent tinkerer is to save all the parts" aldo leopold
#14848 08/12/2002 7:37 PM | Joined: Feb 2001 Posts: 1,897 Member | | Member Joined: Feb 2001 Posts: 1,897 | While it is not a direct bolt in replacement engine. it can and has been done. . . OH,, save all the parts
#14849 08/12/2002 8:33 PM | Joined: Jun 2000 Posts: 2,773 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 2,773 | Mechainiac's right. The 230 is a narrower block, requires different motor mounts. Your tranny should bolt up to the bell-housing, the 230 used the SM-420. Better engine than the 235, but not as good as the 250 or 292. Depending on the budget, I would go with a 261 if I wanted to stay with the existing mounts, or a 250 or 292 if I were willing to change the mounts.
Fred 52 3600 69 C-10
