8 members (57 Drifter, Bill Hanlon, 3B, Gdads51, Otto Skorzeny, Gray_Ghost, DennisM, rick46ia), 45 guests, and 3 robots.
Topics128,022
Posts1,055,362
Members48,420
#14847 08/12/2002 7:16 PM
Junior Member
Junior Member
a guy wanting to sell me a 1965 230 engine says i can use the transmission, etc in my 49 3600.
i can't find any articles saying this is true, 235's up to 1962 seem to me the correct swap
" the first rule of the intelligent tinkerer is to save all the parts"
aldo leopold
#14848 08/12/2002 7:37 PM
While it is not a direct bolt in replacement engine. it can and has been done.
OH,, save all the parts
cool
#14849 08/12/2002 8:33 PM
Mechainiac's right. The 230 is a narrower block, requires different motor mounts. Your tranny should bolt up to the bell-housing, the 230 used the SM-420. Better engine than the 235, but not as good as the 250 or 292. Depending on the budget, I would go with a 261 if I wanted to stay with the existing mounts, or a 250 or 292 if I were willing to change the mounts.
Fred
52 3600
69 C-10
