7 members (tclederman, Woodcmiami, Hotrod Lincoln, Otto Skorzeny, 2-Ton, bobfake, 1 invisible),
41
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,091 Posts1,056,034 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2022 Posts: 33 'Bolter | | 'Bolter Joined: Jan 2022 Posts: 33 | Is there any way I can determine what type of oil to add to my dump bed? OR, will mixing mineral oil and hydraulic fluid be ok so I don't need to worry about it? Truck is a 57 6300 grain truck. Dump has 3 cylinders, one in the front to get the lift started and two longer ones in the rear. It all works fine but it drips a little when parked so I am thinking I will need to add fluid at some point. | | | | | Joined: Feb 2016 Posts: 1,987 'Bolter | | 'Bolter Joined: Feb 2016 Posts: 1,987 | Tractor Supply has hydraulic oil for tractors, I buy it in 5 gallon buckets for the transmission and hydraulics in my 1955 International Harvester. Or you could use snow plow hydraulic oil, Western Plows has it in 1 gallon jugs.
| | | | | Joined: Jan 2022 Posts: 33 'Bolter | | 'Bolter Joined: Jan 2022 Posts: 33 | I have bought the universal oil for older tractors I have had. Was just wondering if it mattered if I mixed that with whatever is in the truck now. | | | | | Joined: Feb 2016 Posts: 1,987 'Bolter | | 'Bolter Joined: Feb 2016 Posts: 1,987 | I doubt it will harm anything, as long as it doesn't foam when pumping it should be ok. I assume it's a PTO driven pump?
| | | | | Joined: Feb 2004 Posts: 29,792 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,792 | A lot of the older dump trucks I've serviced used plain old 30 weight non detergent motor oil in the dump system. One of my customers with a leaky cylinder packing bought the stuff a case at a time. His frame and rear axle had no problems at all with getting rusty! Jerry
| | | | | Joined: Jan 2022 Posts: 33 'Bolter | | 'Bolter Joined: Jan 2022 Posts: 33 | | | | | | Joined: Dec 2018 Posts: 2,450 'Bolter | | 'Bolter Joined: Dec 2018 Posts: 2,450 | mdkelley I just use hydraulic oil like a backhoe uses,get it at the farm store. | | | | | Joined: Jan 2022 Posts: 33 'Bolter | | 'Bolter Joined: Jan 2022 Posts: 33 | sounds good. I read that if I am worried I can drain some oil from the truck, mix the new with the current in a jar and shake it up to see if it blends or gels... if it mixes well there should be no issues. thanks for the replies | | | | | Joined: Jun 2022 Posts: 557 'Bolter | | 'Bolter Joined: Jun 2022 Posts: 557 | My 57 6400 uses plain 30 wt. Non-detergent is best. Doesn't foam. Be sure to lay a 4x4 post in the hinge crotch if any service is to be done with the lift up. Safetysafetysafety. Should a hose burst that bed can slam down before one can get out of the way.
~~ Jethro 1954 3100Back to LifeIn the Dity Gallery1951 3100 (gone) / 1956 4400 (still in the neighborhood) / 1957 6400 with dump body (retired) / 1959 3100 panel (in the woods junked) / 1978 Custom Deluxe K10 / 1993 S-10 4.3 / 2004 Chevy Crew Cab / 1945 John Deere H / 1952 John Deere B / 1966 John Deere 2510 / 1967 John Deere 1020 | | | | | Joined: Dec 2018 Posts: 2,450 'Bolter | | 'Bolter Joined: Dec 2018 Posts: 2,450 | mddkelly In the olden days some lubricants when mixed would basically turn into soap,I don't think you'll hit that now. That was in the forties. | | | | | Joined: Nov 2019 Posts: 150 'Bolter | | 'Bolter Joined: Nov 2019 Posts: 150 | For what its worth, I run plane jane ATF from the farm store for hydos on all the farm trucks and small equipment for year round use. Regular hydro oil doesn't like the cold weather until its warmed itself up, which isn't really possible on a dump bed like it is on tractors/equipment with hydrostatic drives. | | | | | Joined: Feb 2016 Posts: 1,987 'Bolter | | 'Bolter Joined: Feb 2016 Posts: 1,987 | The snow plow hydraulic oil that Western Plow markets looks and smells like ATF, might have some additives but who knows.
| | | | | Joined: Jan 2008 Posts: 4,961 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,961 | I use AW 32 hydraulic oil in systems with hydraulic rams. Since you probably have no idea what the previous owner used, I would drain the system. It is probably about time for fresh fluid anyway. AW 32 usually costs about $65 for 5 gallons. | | | | | Joined: Jan 2022 Posts: 33 'Bolter | | 'Bolter Joined: Jan 2022 Posts: 33 | I use AW 32 hydraulic oil in systems with hydraulic rams. Since you probably have no idea what the previous owner used, I would drain the system. It is probably about time for fresh fluid anyway. AW 32 usually costs about $65 for 5 gallons. I was thinking along the same lines... | | |
