3 members (cmayna, TUTS 59, 1 invisible), 146 guests, and 3 robots.
Topics128,070
Posts1,055,896
Members48,428
#1484582 01/22/2023 1:59 PM
Does anyone know if the master cylinder for a two ton (6400) is the same as for the pickups? I can find ones for pick up everywhere, but nothing specifically for the 6400. If it matters, I have Huck brakes.the only number on it is Wagner JK27, but that crosses to many different styles of master cylinder.
1954 Chevy custom 261CID, T-5 5 Speed.
1952 Chevy 6400 2 ton hydraulic flat bed.
oldieoldie #1484590 01/22/2023 2:40 PM
oldieoldie The big trucks have a much bigger (bore) than 3100 takes more fluid on 6400.
oldieoldie #1484594 01/22/2023 3:10 PM
oldieoldie,
It is not the same as the 1/2 ton, but same for 3/4 ton (Commercial) and up through "Utility" trucks (which includes your 6400). See snapshot below (red arrow indicates your application) from this page CYLINDER ASSEMBLY, Hydraulic Brake Main
A further check of the GM# 5454382 cross references to Dorman M9220. Search that number on the web and you will find a whole bunch of vendors offering it for various prices, some much better than others - LOL.
Hope you find this helpful?
Dan wave
Screenshot 2023-01-22 at 08-54-33 1929 - 1957 Chevrolet Master Parts & Accessories Catalog.png (523.38 KB, 140 downloads)
1952 6400 Brake master cylinder info
~ Dan
1951 Chevy 3 window 3100
oldieoldie #1484957 01/24/2023 11:39 PM
Big Bolt Forum Co-moderator
Jim Carter Truck parts have master cylinders for 2 ton trucks.... https://oldchevytrucks.com/me166.html
1948 Chevy 2-Ton
oldieoldie #1486574 02/05/2023 4:43 PM
I found one thanks everyone.
