| | | Forums66 Topics128,264 Posts1,058,356 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2006 Posts: 32 Junior Member | | Junior Member Joined: Jul 2006 Posts: 32 | | | | | | Joined: Mar 2005 Posts: 267 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 267 | obsa i was thinking it might be a diesel or something. the intake and exhaust are on the passenger side . i could not get a better driver side pic without a chain saw tom
I don't suffer from insanity, I enjoy every minute of it!
| | | | | Joined: Mar 2005 Posts: 267 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 267 | obsa i went back this morning i was wrong about the diesel part. is a 302 really that big ?
| | | | | Joined: Jul 2005 Posts: 117 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2005 Posts: 117 | Nice trucks. I'd enjoy getting some parts from them. | | | | | Joined: Jul 2006 Posts: 584 'Bolter | | 'Bolter Joined: Jul 2006 Posts: 584 | My Goodness, hard to see where the truck stops and the shrubs start!
Question, Are these 5th wheel set ups the same thru the years? Meaning can you take an older truck like this or even 40's and pull a modern trailer with em? | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | It's not a 302. GMC had 2 different inline 6 cylinders, "smallblock" and "bigblock". The larger engines, I think were up to 500+ cid, were used in the 5 ton and up trucks. I remember seeing one a couple years ago at the Hoosier Swap meet. Thought it was a deisel, too. Then I saw the plugs and distributor. I'll check my resources to see if I can come up with some more detailed info on them. I do know that they were replaced in late '59/'60 (depending on model) with the 60 degree V-6, V-8, and V-12.
Bill Burmeister | | |
